Score a FREE Membership sticker when you sign up for a Premium Membership and choose the recurring plan.
ID 1986 K30 Crewcab No Longer For Sale/Trade
Discussion in 'Complete Vehicles' started by LNielson, Aug 12, 2017.
  1. LNielson
    LNielson Registered Member Premium Member
    Jun 11, 2009
    61
    13
    SE Idaho
    Build(s):
    Decided to hang onto my truck and figure out where to park a new K5 Project too....
    1986 Chevrolet 1 Ton http://www.ksl.com/auto/listing/3967785
    Time for a new project for me, Looking to sell or trade this truck for a K5 in similar condition. Asking $4,200
    I'll put up some pics tomorrow.
    350 SBC, 20,000 miles on rebuilt motor, runs very strong.
    -Edelbrock Performer EPS Intake and matching cam
    -Holley Street Avenger 650 CFM Carb
    -Gear Reduction Starter and remote Solenoid
    -Headers, Dual Exhaust, 50 Series Flow Master Mufflers
    -Factory 6.2l Diesel Radiator, much larger than gas engine radiator
    -Windstar Electric Radiator Fans
    -Battery replaced in 2017
    SM465 Transmission
    -32 Spline Output
    -Factory Hydraulic Clutch w/External Slave Cylinder Bellhousing
    -Clutch replaced with rebuilt motor
    NP205 Transfer Case
    -32 Spline Input
    -Round Pattern
    -Passenger Side Front Output
    Completely New Drivelines built in 2016
    -New Carrier Bearing on Rear Shaft
    D60 Front Differential
    -4.10 Gears
    -New Kingpin Bushings
    -Currently has bad pinion bearing
    -Have Yukon Gear D60 rebuild kit and Spicer Ujoints ready to install
    14 Bolt Full Floater Rear End
    -4.10 Gears
    -DIY4x Rear Disc Brake Conversion
    -Factory '86 3/4Ton Front Disc Calipers and Rotors on the rear axle.
    4" Lift
    -Tuff Country HD Springs in Front
    -Factory 56" rear springs and lift block in rear
    37" x 12.5 x 16.5" Goodyear MTR Tires
    -Tires are in good shape, about 85%
    -Matching fullsize spare
    -Aluminum 16.5" rims
    Crossover Steering Conversion
    -Steering Gear Box from 2wd Truck
    -Drop Pitman Arm
    -Offroad Design Steering Arm on Passenger Knuckle
    -Offroad Design Draglink
    -Steering Shaft from Jeep XJ to eliminate stock steering Ragjoint
    Hydroboost Brakes
    -Completely replaced all components 5 years ago
