1989 Suburban TBI trouble
eclipse85k10
Squareless
Washington State
I've been searching and reading topics to try to pin point my problem and getting exhausted here. Basically over all my tbi 350 suburban started running like absolute garbage a few weeks ago. It sputters, hiccups, misses and ultimately runs bad.
Things that have been replaced in the last 2 years and it had a period where it sat for a few months and started driving it again for a few months no problem before it started causing trouble
New distributor
Cap wires and plugs (i've checked them out they look good)
Throttle body rebuilt by a local carb shop
All new sensors, map, tps, iac, egr solenoid, o2, water temp sensor
I've done a vacuum leak test on my egr valve and as well checked all my vacuum lines and a new pcv valve.
The fuel pump was replaced probably 6 years ago and fuel filter recently.
I've also timed 3 times and thats with the single wire on the firewall disconnected.
I may be missing something i've tried but worn out on ideas and searching for a problem!
I replaced the same coil 3 days in a row after breaking down on the exact same exit going to work. Replaced it on way home at same Advanced Auto and in the am it would repeat. Now has a junkyard coil on it and it runs perfectly.
What's your fuel pressure? What's the spray pattern look like? All vacuum lines hooked up properly, not cracked?
I had ignition module failure because I'd wired the alternator without a resistor (thanks Painless - I followed your advice). It did exactly what you describe. Do check your electrical system - if the alternator is failing, it will cause a myriad of problems.
That said, the problem is far more likely something plugged or a failing fuel line. Methanol and older rubber hoses are a bad mix - especially after sitting for awhile.
good luck!
Thanks Scott still regretting not doing the swap.
I think I'm gonna replace the coil as i don't think that's been done.
Haven't found any vacuum leaks yet.
