1991 K5 Blazer transmission
Rhinodrvr
Registered Member
Pensacola, FL
OK...I am ready to scream!!!
I have been working on my 91 K5 and after a new GM crate motor, botched motor install, transmission rebuild, botch transmission install...I was back on the road!!! FOR A GRAND TOTAL OF 761 miles!!!!!
Driving home this evening the transmission quit pulling with NO warning. Fluid level is fine but no gears work at all. I have had/chased little gremlins but thought I was over all of these hurdles...the only thing left was the speedo/cruise control that I think is the DRAC module (other posts).
Beyond frustrated...not looking for a course of action...transmission is still under warranty but just need to vent!!!!
Did you check to see if the transfer case slipped into neutral? does the vehicle hold in park or does it roll or click?
It holds in park. I did try to engage the transfer case but it did not engage. It was in 2WD when it happened. I do hear a clicking sound from under the truck but nothing is leaking, fluid level is good.
