Hopefully I will be doing mine soon.The "impression" in the floor is kinda half there but not fully. Its enough to get you aligned front to back but depth you have to cut a little at a time if you don't have the template from a manual truck.
I used the backing plate as a guide to how far I should cut and it came out pretty good. The wires/receptacles for the shifter bulbs were actually already there. Just had to put lightbulbs in them.
Interesting enough the 98' Np241 with a 27 spline already had the skinny 6010N bearing in there. The planetary is the same Np246/Np241 so I just put the whole thing in. So if any body needs a spare 241 6 pinion planetary I have one with 27 spline input. 95' and up.
Need to get more pics of the completed bezel but I got the whole stock setup out of a 96' off ebay. Didnt feel like crawling around a u pull at -25 degrees.
Used the front driveshaft out of the wrecked 96' which had an Np243. Ended up using the rear shaft as well since after the swap i noticed the Np241 is 5/8" shorter on the rear than the Np246.
I used Laurence LT Tolmans video on YouTube for guidance on this whole swap. He says you can reuse the 246 rear shaft but I felt a little bit too much up/down play with it splined in for my taste. I had the 243 rear shaft so I measured and sure enough its longer so I put it in.
Is that the spot for the nv4500 also there?
