85mudr
Registered Member
I have a 1999 S10 as my dd. The front ring tried to "walk" the pinion and this caused it to crack the housing in three pieces and droped the drive shaft. By the time i could pullover off the highway ( running 75 ) the front outboard cv exploded and this caused the wheel bearing to give way and the wheel went back into the fender causing the knuckle to bend. Anyway would a 1996 olds bravada 3.73 geared diff, and knuckles work in the 1999 chevy? I know that the Bravada is all wheel drive and its common to swap the passenger side shaft to eliminate the selector fork on the chevys. I just dont know if the knuckle on the chevy is larger being a zr2 and the year difference? Any help would be greatly appreciated. Thanks
