2000 Silverado 1500 2wd 5/7 drop DD.
Discussion in 'Other Rides' started by GWeakland620, Apr 25, 2017.
  1. GWeakland620
    GWeakland620 THE CK5 Crayon Eater Premium Member GMOTM Winner
    Sep 15, 2010
    14,388
    13,136
    Toe-peek-ugh, KS
    Build(s):
    4
    This truck hasn’t had a horn since I bought it back from my brother. So today I grabbed some horns off of a Buick Roadmaster. I never knew they had 4 notes. Explains why they are so loud.
    max 02, AJMBLAZER and imiceman44 like this.
  2. campfire
    campfire Adventure is out there! Premium Member
    Jun 7, 2013
    24,133
    13,181
    Northwoods Wisconsin / da U.P.
    Build(s):
    3
    Should have brought the whole wagon home with you... :deal:
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    14,355
    1,606
    Stevens Pass Highway, WA
    Build(s):
    11
    Those holes in the top flange of the c notch are a really bad idea. The top and bottom flanges are your primary load path in your frame. A c notch is bad enough structure but those holes are a big issue. I would reroute those wires and cap the holes.
  4. GWeakland620
    Sep 15, 2010
    14,388
    13,136
    Toe-peek-ugh, KS
    Build(s):
    4
    If I pull a part from a car, that means it was totaled. Terrible idea.
    That top piece is a solid rectangle tube, then the upside down “U” shape on the side is a plate that is welded all the way around. This was done years ago, and since then the truck has hauled a lot, including a pallet of sod. It’s fine.
  5. GWeakland620
    Sep 15, 2010
    14,388
    13,136
    Toe-peek-ugh, KS
    Build(s):
    4
    Plus it wasn’t a wagon lol.
  6. campfire
    Jun 7, 2013
    24,133
    13,181
    Build(s):
    3
    Details, details. :rolleyes:
    Being an un-wagon makes it distinctly un-cool.
    Scribbles likes this.
  7. campfire
    Jun 7, 2013
    24,133
    13,181
    Build(s):
    3
    Never tell an engineer that... :whistle:
    :wink1:
  8. campfire
    Jun 7, 2013
    24,133
    13,181
    Build(s):
    3
    I think we had this same conversation about spacing down the transmission crossmember in your Jimmy. :deal:
  9. kennyw
    Jun 9, 2002
    14,355
    1,606
    Build(s):
    11
    My answer is it's fine until fatigue sets in...
    tRustyK5, GWeakland620 and campfire like this.
  10. imiceman44
    imiceman44 Hoarder extraordinaire Premium Member
    Aug 5, 2002
    20,236
    4,117
    Lincoln, CA
    Build(s):
    5
    I would be so rich if every time I tried to give structural advice and was met with the "it's fine " I would say just give me $10 when it fails.
    Because it will fail.
    campfire likes this.
  11. GWeakland620
    Sep 15, 2010
    14,388
    13,136
    Toe-peek-ugh, KS
    Build(s):
    4
    Lol I guess I'll keep you 2 posted when that day comes.
    beags86 and Smokinthehippies like this.
  12. GWeakland620
    Sep 15, 2010
    14,388
    13,136
    Toe-peek-ugh, KS
    Build(s):
    4
    So the front end rebuild has started. RH front wheel bearing was howling like crazy. I’ll post that video in a little bit. Got the controls arms off to see that the lower bushings are pretty toast. Uppers are dry cracked, but not terrible (I’ll still replace them). The shocks have a dead spot right at ride height, so I will be replacing them at the same time.
    So the plan is replace bad bearing. New poly urethane bushings up front. New Belltech Nitro shocks. Then an alignment. Should be a whole new truck when I’m done.
    Scribbles and Truckman4life like this.
  13. GWeakland620
    Sep 15, 2010
    14,388
    13,136
    Toe-peek-ugh, KS
    Build(s):
    4
    Had a busy day yesterday. All finished up minus an alignment And sway bar bushings.
    Ended up just doing new loaded control arms. Pressing the bushings out proved to be impossible for some reason.
    Smokinthehippies likes this.
  14. GWeakland620
    Sep 15, 2010
    14,388
    13,136
    Toe-peek-ugh, KS
    Build(s):
    4
    Now that this truck is squared away for a little bit, I’m going to tear into the front suspension of the diesel and figure out the bushing/geometry issue with the front springs. Maybe throw a 4wd trans in it if it gets finished.
    Scribbles, beags86 and max 02 like this.
  15. beags86
    beags86 Eastbound and Down Premium Member
    Jan 18, 2011
    11,078
    13,908
    Northern Illinois
    Build(s):
    3
    :thumb:
    GWeakland620 likes this.
  16. GWeakland620
    Sep 15, 2010
    14,388
    13,136
    Toe-peek-ugh, KS
    Build(s):
    4
    Pops got a smoking deal on some camper shells and tonneau covers. I happen to snag one from him.
    fourwheelerjeff and max 02 like this.
