well update time
she started again tossing p0087 code . she did it to me 6 times in 20 mins the other day . was climbing a good grade of hill with a big elevation change .
so the weather is nice out and i dug in to the filter and suction hose side at the filter head .
got the rebuild kit napa # 827-0110 under 30 bucks . listed for 2500-3500 trucks only but ass was the same as my 5500 med duty truck .
got 2 foot of hd fuel rated 1/2" hose and 4 clamps . ( side note get 3ft of hose the extra will make it nice and lay out the radius better in the bend )
the rebuild kit went good and super easy no problems .
the original hose from filter to cp3 line at engine once i removed it and removed the anti chafe stuff i found the hose was 3/4 flat just laying on the bench . so i bet it was sucking flat on my as with no real effort i can pinch it clean off .
the med duty 4500-5500 engines have the filter on the driver side . it makes it a bear to get at . i had never done one and it took me 1.5hrs . had to remove the boost tube / move the coolant bottle away / remove 2 massive electrical plugs and brackets . then she come out . i then re positioned the nipple angle for the filter to cp3 hose to help the radius of the hose not to try and kink . this is were the extra 1ft of hose could have been better to let me make a big sweeping arc .
fired off good with 1 pump up and 1 re-pump of the plunger after stall out . but no leaks and restarts fine after sitting .
so the next few days will see how she does driving .
@Russell @Fastereddie @bigblock72
