208 to 205
WJACKSON11X
Madison,GA
Fininshing up the rebuild on the 205. I currently have a 700/208 combo and want to install the 205. I've got the 350 adapter and the spacer for the trans. What crossmember will I need to use for the 700/205 combo. I believe the 350 adapter is much taller than the 208 adapter that I have. I've tried to search, but all of the combinations has confused me a bit. Would I be better off just building my own crossmember? Pics of any other 208/205 swaps would be great as well. Thanks
Im sure your aware, but your going to be losing a lot of low range switching to the 205.
That being said, I love my twinsticked 205. Front wheel drive burnouts are fun.
Yeah, I know I'll be losing a bit of low range, but I think the twinstick capability and strength upgrade are worth it.
Now if I can just find the crossmember I need
This is the only one I have, but I can take another one tomorrow when I go to my shop, if needed.
Is this the crossmember needed? (the flat one). I'm using the tall 350 adapter, not sure if there is a short one.
It looks close to what mine is. Mine does look like the ends curve up more. I also have some spacers between mine and the frame.
1/2 and 3/4 ton use flat with curved ends.
the true 1ton truck frames use that one pictured almost dead flat. as the frame is 2" taller basicly over the 1/2 and 3/4 ton stuff.
but you are getting warmer . . . :whistle:
Is this the one?:dunno:
