24v/12v Golights
gimpyrobb
cincinnati
I ended up with some of these Golights. They are black and have a wired joystick to control while in the vehicle and a wireless remote for when you are outside the vehicle. They are rated at 400,000 candle power and come wired for 24volts. If you remove a resistor inside the housing, they run on 12 volts.
$165 each shipped.
$850 for a case of 6.
Designed for use in all weather conditions and produces 1,300 lumens of intense light output. These units
feature remote control operation that allows users to rotate the light 370 degrees with a hard stop and to adjust vertical tilt through 135 degrees.
Remote operation is provided by one handheld wireless remote controller that operates over a radio frequency of 433 MHz. This remote includes
an internal 12 volt battery rated at 1 year of operation and a single red LED to indicate remote control activity. The remote controller has a range
of up to 100 feet and will operate through walls, within structures, and in vehicles. The remote is constructed of polycarbonate with rubber push
pad buttons for weatherproof durability and can be user programmed to operate one or several lights simultaneously. Remotes are 3 inches long
by 2 inches wide by 3/8 inch thick. This model is the bolt on style.
I'd like to get one next week already converted to 12V. :D
I prefer check/money order, but will; take paypal if you cover their fee or send it as a gift. Let me know whats best for you.
