2wd steering box questions
mudman83
Mesa, AZ
Will a two wheel drive steering box work with front to back styeering? I need to change mine and know that someday I will want cross over, but have to keep the stock steering for now.
Thanks,
Kyle
nope you need the 4 wheel for now then you will have to swap to the 2 wheel gear.
Why would it not. Just put the pitman arm 90deg off from where it is mounted for the crossover. It would move front to back just fine...
negative...the 2wd sector shaft and pitman are are keyed to only go on one way...
News to me since I just installed one a few weeks ago.
The 4x4 shaft is keyed for one way. The 2x4 shaft is keyed every 90 deg.
Or am I completly lost here?
mine was only keyed to go on one way.. I may be mistaken though b/c it has been like a year and I have def. been drunk and slept since then...
Chris
I agree my 2wd box has four key-ways and a big nut on the bottom. The 4x4 has a flat spot on the shaft so it can only go on one way. At least all the boxes I have seen were this way.
Yep that is the way mine is too
was just messing around with a two wheel drive box today and and it looks as if it should work just fine if you turn it 90*
I would assume that as long as you have the crossover pitman arm on the 2wd box then YES you could install it so that it will push/pull. The 2wd box's are clocked every 90*
What year and truck should I get one off of? Also Should I get the normal 2wd pitmann arm or do a need another one?
The year will depend on what type of fittings your lines use. Up until 1980 the lines had flare fittings then starting in mid 1980 they changed to O-ring style fittings. You will need a pitman arm from ORD for use with crossover steering then just install it so that it can push/pull.
