3/4 ton axles 4.10
Artemis Entreri
Staten Island, NY
Ok so while the weather is nice and before it gets too hot, I want to do this 3/4 conversion into my 91k5.
So I need a set of axles, either 10 bolt/14bff or d44/14bff with 4.10 gearing.
In the NY area.
Want to see if there is something semi local I can find and afford that will bolt right into my truck as I dont have time or ability to do much conversion, lol.
SO anyone with anything?
Ihave a set of one ton axles with 410 gears matched front and rear,the rear already has disc brake conversion,rotors and brake lines im asking 700
my cell is 973-600-1798
I have a set of 3/4 tons,rear 14bff, disc braked in the rear and a strong posi, 4.10's With a track bar bracket on the axle already.
10bolt 8 lug front plus a spare housing and center section. both are complete brake to brake,
Make an offer, I'm on the North shore in Mass. I can meet ya half way if you want too
Lemme know.
ok but the 14 bolt ff from a 3/4 or 1 ton will be the same and the front 60 bolts right in and the steering set ups are the same as a 10bolt 1/2 ton or 3/4 ton
No proble at all bud, nice to meet ya. Although, you had me a little nervous (2 and a half 3/4 ton axles in the back of a K5 with the tailgate down) Reminds me of when I put a fully dressed smallblock bolted to a TH350 in the back of an escort wagon:haha: I swear the front tires came off the ground every bump I hit:haha:
Haha it actually drove back to NY with no problems at all, set cruise to 65 most of the time and just sat back and enjoyed the ride.
Tho, we did stop at a McDonalds and I looked out the window of the place to see a circle of people pointing at the truck and trying to see what it all was without getting too close, I had a chuckle as I ate my burgers.
