35" bfg with a 2" lift ?
sixb
West Jordan UT
Right know my 84 k5 is in pieces, but when it's done it will be sporting a 92 5.9 6bt cummins and a 1990 np 205 fron another Cummins application along with a 1997 HD NV4500 also from a Dodge Cummins. The rig presently has a 4" lift with a 6.2 Detroit, np208 and 700r4. I figure I will loose a couple inches up front with all the extra weight I will be adding and want to know if the 35" tires will still clear, Thanks.
35's on 2" of lift will be fine with some trimming! But, will your front axle have enough space from your oil pan at only 2" lift? IIRC I've heard 6" lift is needed (for 4" actual lift) to keep the front axle outta the 6bt. Anyways, sounds like a sweet build, good luck man, post some pics when ya get a chance!:D
