37" tires how'd you do it.
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 70~K5, Jul 25, 2002.
  1. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    37\" tires how\'d you do it.
    For those running 37"/38" what did you have to do to run them? And how much did you have to trim?
  2. Scorpion
    Scorpion Registered Member
    Jun 5, 2002
    60
    Denver, Colorado
    Re: 37\" tires how\'d you do it.
    I have a 6" softride suspension lift and I can say that I don't have more than an inch to spare with 35's. I'd think an 8" lift would do the trick nicely...or a body lift.
  3. Greg72
    Mar 5, 2001
    16,181
    2,393
    Austin, TX
    Build(s):
    3
    The trick is to buy them but leave them unmounted in your garage like me......no rubbing, and they'll last forever that way!
  4. dr1553
    dr1553 Registered Member
    Nov 4, 2000
    90
    Lake Jackson, Texas
    Scorpion,
    Do you think the TSL SX's 35x15.50 would fit with the 6" softride. Full flex and all?
    Thanks,
    David
  5. Scorpion
    Jun 5, 2002
    60
    Denver, Colorado
    I think you'd have a problem rubbing up front when turning the wheels because of the width of the tires. The lower part in the front of the wheel opening on the front fenders (where it comes to a point) seems to be an issue with a 6" and tires that are larger than 12.5" wide (I know this because mine are 12.5 Mud T/A's and the clearance is just enough). A little fender trimming would probably resolve it though.
  6. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    Im running 37 ssr's on 16x10 aluminum wheels with 8" superlifts. Ive rubbed the tires on the backside inner fenders thrashin on it at the dunes, but not too bad.
  7. wheelin72
    wheelin72 Registered Member
    Mar 6, 2002
    97
    Hanford, CA
    cornfed how do those ssrs perform.?
    are they lighter than a tsl?
