I've never messed with SM-465s before, don't know the differences if any at all. Trying to find out how to put the 2 together. Guess the 4wds have 10 spline, and the 2wds have 35? Anybody?
I believe you need a round pattern adapter and swap the GM input gear into the Ford case. If you search around I think you'll find the info. Maybe check over at Pirate too.
Don't want to go with a doubler, just want to try a 4 speed. Never had one, and drove one for bout a week, kinda liked it.
I have access to at least three 465/205 combo's, one is in an 86 1 ton that I parted out. Getting a Ford case is easy, and since I already have the combo, should be just a matter of swapping the inputs, and opening up a couple of the adaptor holes.
