4 wheel drive crew cab owners please read!
cybrfire
1 ton status
Iowa
If you have one, can you measure how far below the frame your Tcase hangs?
Thanks!
Got mine mounted and I think it hangs a might low.
Thanks! Mine is lower than that yet.
Well it seems I am not the early bird!! Measured this mornin, 205tc was 3 1/2 inches below frame and the crossmember was another inch below that.These measurements are with the crossmember above the frame with a original rubber mount,if it makes a difference.
One ton or 3/4 frame? Going to make a difference.
I asked a similar question, my setup in the K5 frame looks like it hangs down WAY too far, although it lines up with the crossmember ok.
I don't think so on a Crew Cab. They are all 8" frames unlike the std cab trucks. Someone correct me if I'm wrong.
I believe all the crewcabs have the taller frame. 8" sounds about right.
This is a conversion project so I really didn't have anything to compare too. Divorced 205 and its in a 2wd crewcab that I'm converting. It's hanging there now just looks stupid low. The crossmember for it is above the transfercase not below so it just looks different. I think I'll leave it for now. If nothing else my driveline angles are better and its a tow rig so break over angle is not a concern. Thanks for the measurements though guys. That gives me something to compare too!:wink1:
Hmm, I don't think I remember mine looking like it hangs down too far. 3.5" might sound right.
Picturessssss?????????:D
