400 - 2bolt or 4bolt?
Discussion in 'The Garage' started by Buttrash, Jun 6, 2002.
  1. Buttrash
    Buttrash Registered Member
    May 24, 2002
    17
    Just curious...
    I've heard if you're going to build up a 400 block it is more desirable to get a 2 bolt main block and then have splayed caps?
    Any oppinions on this?
    Thanks.
  2. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    That's correct. The 400 small block with 4 bolts were weaker than the 2 bolt ones. Finding a 2 bolt main block and having it made into a 4 bolt with splayed end bolts is much stronger.
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    You are correct. But you probably wouldn't need to go to the trouble unless you are going to build a motor with massive horsepower.
  4. Buttrash
    May 24, 2002
    17
    What other way is there to build a motor? /forums/images/icons/smile.gif/forums/images/icons/cool.gif
