I put a Jegs in-house brand, 168 tooth, external balance, SFI rated flexplate on my Chevy 350 with one-piece rear main seal. My transmission is an early model 4L80E. The original flexplate had 6-bolts bolting the flexplate to the torque converter, but with this new SFI flexplate only three of the bolt holes line up. The other three in the flexplate appear to be for a smaller diameter high stall converter. My question is...are the 3-bolts going to be enough for the torque converter? I also have a mini high torque starter, and the teeth engagement clearance is perfect for the flexplate. I have tried looking for info on 4L80E SFI flexplates, and there is nothing out there on except for people doing LS1 engine swaps.
