IIRC the bridge support for the pinion pilot bearing will interfear with the ring gear teeth with ratios that are numerically higher. I have had to machine certain Ford 9" cases when installing 6.50 gears in them in the same place just for that reason.
I'd be willing to bet that a 5.38 gear set could be made to work but I would not look for anything higher.
Tom
Tom
