skark_burmer
I've been having an annoying hot start issue with my 6.2 for some time now and im slowly eliminating possible causes. It starts fine when cold but when hot it will not start. It will crank just fine but produces no smoke out of the exhaust even with the throttle to the floor and cranking for 5 to 10 second bursts. That tells me i am not getting furl to the cylinder. I wont go into too much detail but i figure shared information is a good thing so i'll keep posting until i solve the problem. If i use starter fluid (yes, i know i am taking my fate into my own hands. no need to flame on this issue) i can get it to run for 3 seconds or so before it dies out again. After doing this 2 to 5 times it will keep running.
First i thought it was a fuel delivery issue and the lift pump was failing, so i replaced the lift pump. No change, (although the new one builds 4 more psi.)
then i thought it was some clogged filters (even though i just replaced them not too long ago) because i run SVO or Biodiesel depending on what i have laying around, but that didnt help.
Then i though id install an electric lift pump (and pre filter) to make bleeding the system easier and to make 100% sure i have no air in the lines, but it still will not start when its hot.
I just read a post by batmanjr (from 2003) that said the shutoff solenoid on the IP is failing and normally gets worse when its heat soaked. It makes sense and the symptoms fit what i am getting so i am going to try that next. I'll keep everyone posted.
) wire running from the controller to the plugs.
