Looking for a little help. On my rebuild of my Blazer I've found my oil cooler hoses leaking a little oil on the ends near the oil filter. These are the two rubber and aluminum hoses that connect to the two aluminum tubes that run across the radiator rear to the passenger side radiator tank. When I called my auto parts guy he says there is only one part # and one hose listed yet these two hoses are bent in two different configurations. Does anyone know if there is two different part #'s or are they using just one hose now and if there is two different hoses, does anyone have those numbers?
Thanks in advance.
Thanks in advance.
they look like they have barnacles growing on them................................................................................................ I hate RUST!......EVERY thing "wrong" with all my vehicles is related to RUST...seized e-brake cables on my Contour...brake line on my van popped when I moved it the other day...got holes appearing in my trucks rockers now ,and cab supports are crumbling..and my Suburban is not getting any better either,having sat 2+ years since buying it...rear shackles rotted off it last year,along with the u-bolt plates...inner fender rotted so bad on the drivers side,that the valve body for the plow controls moved closer to the firewall,and wouldn't work!..had to booty-fab a "liner" for it out of an old galvanized pool's sheet metal during a blizzard to fix that...rust SUCKS...
