Ok, so i have a friend who has a 94 chevy 2wd with the 6.5 turbo diesel engine.
The injector pump is bad. I'm taking on the job of replacing it but this is my first attempt at working on any diesel engine. I did a little research first and then dove into it tonight. I don't have my repair manual with me so i had to stop for the night but i got as far as removing the intake manifold and all the injector lines and electrical connections and also pulled the oil fill tube out and this is where i'm stuck. If i remember correctly the book said one the oil fill tube was removed that i need to mark the injector pump and the timing cover then through the oil fill hole in the timing cover i need to remove 3 bolt from the gear and then the 3 bolts holding the injector pump and it's ready to remove. Well, through the oil hole i can see the 3 bolts but i also see what appears to be a nut bolting the injector shaft to the gear. I'm guessing that maybe that nut holds a splined shaft of some sort that the injector pump runs off of? Am i correct or does that nut need to be removed also?
Once you start working on the 6.2/6.5 you start to appreciate the simplicity. It's just different than a gasser, and so much easier in a lot of ways.
