I have been having problems with my brand new 670 truck avenger (90670-2) and have searched ever thread on the site this is my last resort. The carb is mounted on a edlebrock perfomer intake manifold on a stock 350.
The problem is when I stomp on the gas it kills the engine instantly. Somtimes it back fires through the carb. If I ease into the gas it has a little hesitation but not much other wise the carb runs great.
Ignition timing is dead on and idle is good and smooth. The carb has been jetted for elevation at 2000ft it has 66 and 86 jets. I changed the power valve to a 6.5 to meet the idle vacum of 12hg. Idle mixture screws have been adjusted to get best vacum which is 17hg I know this is somewhat low compared to what Holley recomends but it is the best I can get. I have also changed the pump jet nozzel to 31, 32, and 35. I have also change the pump cams and tried them all. The pump lever is set perfect for an instant pump shot. I called Holley tech support and they thought it might be a check valve in the metering plate so they sent two new plates and I installed them and the issue remains. I had and edlebrock perfomer 600 cfm carb on before and it ran fine I upgraded to the truck avenger for offroading.
I know that the 670 is somwhat big for a 350 but the Holley techs seem to think that it is fine. Any ideas would be appreciated.
