700r4 Pump seal
sunnyc123abc
SoCal
Ok, so my 700r4 that was rebuilt about 2 years ago, has been leaking really badly since april. First i thought it was the pan gasket, so i changed that. It still leaked, so i changed it to a rubber gasket. That didn't work, so I bought a new pan thinking the old one was warped. Still leaks, so i have tracked the leaking down to coming from the front pump seal where the torque converter is. I know that i need to remove the tranny to change it, but does the seal just pop out or is there something that needs to be removed before removing the seal? Also, I heard that you should change the bushing at the same time. Will i need to remove the pump to do that? thanks
there is a seal retainer that is over the seal, it just unsnaps off. the seal is like any other metal-clad seal.
the bushing on the other hand, well to remove it without pulling the pump requires a very expensive tool, and a not quite as expensive but still expensive installer to not damage it. to pull the pump requires pulling the pan also as the filter and TCC solenoid needs to be removed.
usually when the seal leaks, the bushing is bad. i would check the bushing when the seal is out. also try to stick a finger in there to see if you can move it. ive seen a couple pump housings crack and allow the bushing to spin, the bushing looked very good. i would check your receipts and/or with the rebuilder to see if that bushing was replaced.
man, I just put the new gasket and pan on 2 days ago. Do you have a link to the expensive tool. maybe I can rent it at autozone :D
ill look thew my books tomorrow after work, get the number and look for it online. i don't think you will be able to get it at autozone, most tranny shops ive talked to don't even have it, but i know its in my tranny books.
