700R4 TV Cable Location and Adjustment
bmjwright
Registered Member
Burns, TN
Stupid question, but where is the TV cable located on a 6.2? The 700R4 in my '84 is acting up (dropping out of gear) and I was hoping adjusting the TV would help, but there is nothing under here that looks familiar.
Bunch of vacuum lines that are in desperate need of replacing though.
Hit that button behind the intake....that's your tv adjust. Then rotate throttle open, should hear the ratcheting. Fwiw, mine is about 1/4" of sleeve out.
Those solenoids and vacuum lines go to the EGR valve,and I see yours is unplugged!...also some go to the EPR valve (heat riser looking dewhickey in the drivers side exhaust pipe with a vacuum canister operating it)....
I just left my EGR unplugged and the EPR too,it has a spring inside the canister that opens the butterfly ...haven't noticed any difference not having either of them connected really...if I had a J code intake factory it'd have neither of them anyway...dont know if I'll ever get the ambition to install the j-code one I picked up long ago...
