700R4's from Bowtie Overdrive. Anyone heard about these guys?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Jul 31, 2003.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    700R4\'s from Bowtie Overdrive. Anyone heard about these guys?
    I talked to these guys today, actually they called me. Need more specific info about my rig before they would quote, talked to the guy for 30min. Impressed, very impressed, I'm sure the tranny shop around the corner would never do these things or have their knowledge. And it will cost the same even after shipping, they pay the first $100. So any opinions would be nice. Thanks, Matt.
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Re: 700R4\'s from Bowtie Overdrive. Anyone heard about these guys?
    They build a good tranny for the price.
    I have their 200R Stage-2 in my 71 ElCamino.
    Theres also Art Carr and if you want a virtually distructable trans go here Performance Trans Specialist
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Give these guys a call, Phoenix Transmissions. Just installed one of their 4x4HD transmissions, and very happy with the performance and their service and detail. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    Several members on this board, including myself have purchased their transmissions. I bought the Stage 3 unit for my '90 K5. I did a lot of reading and comparing on the subject. I'm sure you can just as well-built tranny from any of the other vendors (with a few exceptions) but BTO deals strictly with the 200/700r4 trannies.
    For me the decision came down to TCI or BTO. I finally based my purchase decision upon the knowledge of the staff and the word of mouth from many of the members here. I've had it up and operational know for about 2 months and it is a great transmission. Shifts are EXTREMELY firm other than that I couldn't tell you a difference. Based upon my limited experience with the tranny to date and my interactions with their staff I would definitely do business with them again.
    Do a search for BTO and see what others have to say about them.
    You can PM me with questions if you want.
    Lance
  5. 88Silverado
    Mar 13, 2003
    2,664
    distructable
    OOps..made an error, should have been "Indestructible"
    BTOD is good /forums/images/graemlins/thumb.gif
  6. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    Got my stage 2 700r4 sitting on the shelf http://lagparty.org/~mike/700r4.jpg ... its even got the advance adapters short 27 spline output shaft for my np205 t-case http://lagparty.org/~mike/700r4shortshaft.jpg
    they are in hesperia, 1.5hrs from me and I drove up there.. met the owners and some of their employees. steve the owner worked with me beforehand to make sure everything was gonna work out and what not.. I dont have it running yet but I have no doubts that it was money very well spent. do your research and Ill bet you end up going with them.. Also check out their custom designed and engineered TV-cable adapter for retrofitting the 700 into carb'd applications.. My tv-made-ez setup just came UPS today. its genius.. I would highly recommend them.
    mike
  7. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    i started installing my stage III from them today, to get the warrenty they make you do a bunch of stuff, but I can see their point for all of it,
  8. downtime2nite
    downtime2nite Registered Member
    Jan 13, 2002
    20
    washington state
    I installed a stage two in my suburban over a year ago and have had no problems behind a hopped up 350. they have answers to all your questions and help you set it up to perform well. very happy with the tranny. good luck!
  9. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Like what?
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
  11. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I've had the Stage 2 in my 87 for over 5 years now and no problems at all...it shifts REAL firm, almost too firm for me actually...but very good people and stand behind their product...
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  13. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    Cool sight.... /forums/images/graemlins/thumb.gif
  14. 88Silverado
    Mar 13, 2003
    2,664
    Every trans they build gets installed in one of their two test cars. They drive each trans to make sure it is working right before it is allowed to leave.
    In order to get the "User Installed" warranty, you have to perform pressure level checks and they recommend a fluid temp check. It costs about another $50 for the test kit but it comes in handy when you want to change your settings.
    Call them on the phone, give them the readings, if everything sounds OK they invoke the warranty.
  15. 88streetblaze
    Jun 27, 2001
    314
    they make you take pressure readings in all the gears with the detent hooked up, unhooked, and at 1500rpm and full detent,
    they want an inline magnetic filter for the first 300-500 miles
    and they want temperature readings of the trans fluid in the pan, but their pans have the plug for the sending unit already, so thats nice,
    then they give you a very detailed list of driving tests to do of different shifts.
    and when you call they ask alot of questions, how lines are routed, how did you calibrate your dip stick, etc...
  16. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    other then the "extreme hardened sunshell", which I am unsure of, this list is pretty typical of EVERY rebuilders stuff strengthwise as the hard parts are all stock.
    same clutches/bands etc
    try and break down the differences to find what it is you are PAYING $2g for.
    a $150 kit and an hour or so labour plus a few custom sized hydraulic buttons.
    these guys are playing on OUR ignorance.
    this site should be able to weed out a reputable source with the membership base.
    • Superior High Performance Reprogramming Shift Kit
    • Monster Mega Valve and an oversize low / reverse .500 TV Boost Valve, these two valves produce higher pressure and firmer shifts
    • 10 Vane high performance / high volume pump, which have been tested and proven to be stronger than 13 vane pumps
    • Superior Billet Servo
    • Double High Output Pump Slide Spring
    • 29 element heavy duty forward input sprag
    • Extreme Hardened Sunshell
    • New Filter
    • Re-calibrated spacer plate for improved shift firmness
    • New double lip front and rear seals
    • New high temp. center seal
    • Monster Performance 1-2 Accumulator Spring
    • The Raybestos Pro Series black Kevlar band is used that holds in second and overdrive
    • "The Monster" reaction shell, special separator plate
    • Monster intermediate servo release check valve
    • Red Eagle Racing Clutches
    • Kolene Steels
    • 3-4 High-Performance Clutch Pack
    • A 3-4 clutch release spring kit is installed to help prevent 3-4 clutch failure
    • Special Monster governor springs
    • Free Monster Motorsports Decals
    • $150 Refundable Core Charge for most 700R4 units
  17. 88Silverado
    Mar 13, 2003
    2,664
    The question was about BowTie Overdrives...Not MegaMonster.
    I use BTOD transmissions, They're a good trans for the money for those who dont want to rebuild one themselves.
    BTOD will also tell you the differences in the parts between the different transmissions.
    As was posted above, Performance Trans in Sacramento (builders of the 1000+ HP 200R's for Turbo Buicks) and Art Carr in So Cal are highly spoken of on several other performance boards. They also cost more. Do research and choose who your comfortable with. I have had good luck with BTOD.
  18. mike reeh
    Jul 23, 2001
    752
    San Diego, CA
    why are the splines full of crud?
    has it been installed already or ??
    crud? what crud? I dont see any splines "full of crud" but on a related note, yes, they install and test drive every 700 they build in their test nova. So to answer your question, yes it been installed already.
    mike
  19. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    I've had a Stage III in my '90 for 2 years and wouldn't use anyone else. Steve and Chris know GM Overdrives better than anyone else. Their support is second to none!
