73/74 Tub Swap
7D4Jimmy
Registered Member
CenCal
So now that I’ve got my ‘74 Jimmy up and running I’m looking to take care of some of the structural rust issues. Decided it’s beyond patch panels and have a lead on a clean ‘73 Blazer tub. I’m just wondering if there’s any significant differences I should be aware of before I buy it and take on the swap. My belief is that 73-75 are pretty much identical but if anyone has experience on this swap and can share their insight I’d appreciate it.
Yes it should be a direct bolt on swap . , There might be minor differences in the wiring . Not sure what year they went from points to HEI ignition . ( the 73 should be points) and that’s not a hard fix you just need to make sure you get rid of the resitor in the ignition wire. So the HEI gets a full 12-volts
Ok, good to know. I’m not sure what, if any, wiring is on the ‘73...it’s pretty stripped. My Jimmy has been converted to HEI already. Was considering doing a Painless harness at the same time if I can afford it, the Jimmy’s wiring could use some help anyway.
There are a few things that were 73 only. Like the window regulators/door panels. But I cant think of anything directly on the tub. Frames and body mounts are the same.
Ok, perfect. I’m gonna have to source doors and a front clip elsewhere anyway. My doors are rusted out and are missing glass/regulators. It’s just a rolling tub I’m looking at picking up.
One more thing the first year for a factory roll bar was 74, so if you have it, the 73 will not have the captured nut in the floor for it..
Otherwise I think it's a direct swap
Ok, sounds good. Just subtle things but pretty straight forward. I just wanted to make sure I wasn’t gonna run into any big surprises
