I cut a window for access to mount my cage better. Anyone with a 73' thru 75' k5 ever use this area for storage? I know alot cut out the rocker and weld in a rectangle tube for a rocker but you could still run rock sliders under the body to the frame that protects the rockers and use this as some kind of extra storage. Could make a hinge and lock setup of somekind. Its not water tight but I dont plan on mud running, but Im sure i will cross a stream or two. Could coat it inside there. There is a decent amount of room for something. Just a thought. Mine only has surface rust inside, not bad for a 73'. What do you guys think?
. I here ya, It's actually got a good bit of room even with the tire on it for access. Might be a good place for a tow strap or something east to get in & out. It's storage space, got to be good for something.
