'73 K5 Fiberglass Body Tub
  1. 73k5blazer
    Dec 28, 2001
    5,126
    213
    The Rustbelt
    Build(s):
    73k5blazer submitted a new Build:
    Read more about this build here...
  2. Grim-Reaper
    7,385
    Atlanta
    Re: Fiberglass Body Tub
    Well when are we going to see the pictures? hahaha
    Fiberglass, if done correctly is a lot stronger than you would think. With the loss of 1200 lb and the way you mounted the cage I think your going to be ok. As for the seats.. you could probably get away with a plate on the top about 3 inch raidus and a couple BIG fender washers on the bottom.
    Most of the wheeling in MI is mud bogging unless your plan on jumping the dunes. You probably not going to see the frame twisting that some of us see at places like Tellico. just going by your discription your probably fine. Also tieing the cage into the frame you are taking some of that twist out.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  3. 73k5blazer
    Dec 28, 2001
    5,126
    213
    The Rustbelt
    Build(s):
    Ok...you talked me into it....give me a few days, mabey a week or two..and I'll get a bunch of pictures together and scan them in and post 'em...I've been meaning to do it sometime anyhow...
  4. 73k5blazer
    Dec 28, 2001
    5,126
    213
    The Rustbelt
    Build(s):
    Here's those pictures I promised...7 years ago!
    Ok, Since the site seems to have migrated towards 'build' threads, I will finish my project out that way..(Yes, I said finish!)
    First though, here is a conglomeration of years of threads, FYI...
    It started with this:
    1 NIce 1973 K5....well, rusty, but nice, ok it was just ok, it ran and 4wd worked....
    Eventually the rust got so bad, I tore it down for the "summer appearance package". I turned it into a rust hating project, that is now my 10 years running fiberglass body K5 rebuild/resto/mod project...
    I sandblasted the frame (that was 3 days of fun picking sand from my ears), and coated with DuPont Imron (the stuff they use on Airplanes, it's an epoxy paint, I found it cheap then, it's wildly expensive now!)
    I bought the fiberglass body from US Body source (again, it was waaayyy cheaper back then) and started fitting it. I used metal doors and an new GM OEM tailgate. All primered, rustprooffed inside...
    I also fabbed a full cage, starting with a Smittybilt front cage part (another part I don't think you can get anymore), but the Smittybilt cage wasn't such a wise choice, it doesn't hug the contours of the truck very well. It works though, I guess...
    CUstom nerf bars I fabbed that double as cage supports, the glass body needs a full cage with support to frame, this provides said support.
    And that's about where the thread search picks up..I'm sure I've missed many threads here..but...alas...
    Glass Body back from Line-X
    Air tank install
    H2 tire/wheel install
    Started all new wiring, all custom from scratch.
    Everything you wanted to know about wire and more
    Diamond Plate siding
    120v Inverter install
    Battery tray for Optima D31
    Borgeson Steering Shaft
    80's wiper system install
    Kert DIY4x bumpers..
    Bumper accessories
    More Bumper stuff..
    More bumpers
    Delphi Terminal wiring how-to
    CUstom re-worked Dash
    Alum. Radiator install
    Elec. Fuel pump tech
    Tilt front clip supports
    Engine purchase
    And here's how it sits pretty much today:
    With this in my garage...
    Ok, so I have the engine, I've got the clutch, motor mounts and various other pieces required to physically install the motor coming tommorow. I'm thinking I may actualy drop it in on Thruday.
    Of course, "drop it in" is a far cry from "installed", I want to get it in so I can order d-shafts with the whole drivetrain sitting in proper position, and once d-shafts are in, I can do exhaust, all stainless of course. You know I hate rust, that's the whole purpose here you know, rust prevention! :haha:
  5. cdoggwsu
    cdoggwsu 1/2 ton status
    Jan 2, 2008
    1,253
    Olympia, WA
    Man...just finished reading all your previous build thread stuff. Congrats on all the hard work, it's really an amazing build!
    Are you planning on separating the "topper" at some point, or is that too critical for the glass structure?
  6. 73redblaze
    73redblaze 1/2 ton status
    Jun 18, 2008
    3,409
    4
    Aptos ca
    good god man thats beautiful
  7. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    6
    gilbert az
    dear god man you have patience!
    Dont forget the stainless nuts on your exhaust manifold studs:p:
  8. 73k5blazer
    Dec 28, 2001
    5,126
    213
    The Rustbelt
    Build(s):
    THanks for all the kind words! I have a Specialty Top Co fastrac top for it, new in the box, Dontoe clued me off where one was on Craigslist late last year. I figured by the time I get to most of this stuff and work out the gremlins, (remember, many parts are now considered NOS, like I installed an air locker in 1999, it may or may not actually work!), it will be late summer, fall, so I'll just leave the hard top on for now.
    Giddy up.....
  9. 82355
    82355 1 ton status Premium Member GMOTM Winner
    Feb 4, 2009
    14,153
    2,438
    Bradish Nebraska
    Build(s):
    6
    Wow, I am going to go back through and read all of this tonight.
    Martin
  10. mad_burban
    mad_burban 1/2 ton status
    Jun 16, 2008
    335
    Colorado
    I'll 2nd that :bow:
  11. 73k5blazer
    Dec 28, 2001
    5,126
    213
    The Rustbelt
    Build(s):
    Thanks!
    Brown just dropped off some install goodies..
    Centerforce Duel Friction clutch
    Centerforce throwout bearing
    ARP pressure plate bolts
    Motor mounts and engery suspension urethane inserts
    Fuel pressure gauge for initial tuning
    ANd I just finished rebuilding my bellhousing. All cleaned up, NOS clutch fork, NOS clutch fork pivot ball stud, NOS clutch fork rubber seal, NOS Z-Bar ball stud and Z-Bar seals. I rebuilt my clutch Z-Bar with all NOS GM seals and bushings several years ago. I also cleaned up my engine mount brackets with the rest of the yellow Imron the dude sold me cheap when I bought a gallon of black several years ago. He said he had this qt of yellow he sold me at 75% off. I don't like yellow much, but it's good for parts like this...
  12. chevyuser74
    chevyuser74 1/2 ton status
    Jun 19, 2006
    1,473
    Mukwonago, Wi
    subscribed
  13. 73redblaze
    Jun 18, 2008
    3,409
    4
    Aptos ca
    you know how some people spend thousands of dollars on art work by guys like Thomas Kincaid? i would just mount one of those on my wall! it would look soooo much cooler!!!
  14. 73k5blazer
    Dec 28, 2001
    5,126
    213
    The Rustbelt
    Build(s):
    I got some body parts that are nice and jagged and rusty, artwork in their own right, those could be mounted on the walls.
  15. cuervo
    cuervo Wears Boob Goggles! Premium Member
    Jan 2, 2004
    3,344
    265
    Sweet Home Alabama!
    What motor mounts did you buy and where from?
    On a side note: I got my old motor out yesterday and it's the 14093638 casting. I've not pulled the pan to see if it's a 2 or 4 bolt version yet. I'm hoping for a 4 bolt so I can sell it to some racer for a few bucks.
  16. 73k5blazer
    Dec 28, 2001
    5,126
    213
    The Rustbelt
    Build(s):
    I bought these cheap motor mounts just for the clamshell pieces
    THen I drilled out the rivets and replaced the rubber insert with these Energy Suspension urethane inserts. THe instructions say to just use the provided zip ties to hold the clamshell together until you bolt them into place, but I just tack welded the clamshell back together, one less thing the have to align and screw with when the engine dangling from the hoist. The energy suspension instructions also don't mention which way to install those inserts, there are little tabs that need to go a certain way to catch the engine bracket properly, I'm glad I noticed it, that would suck to have the eninge dangling off the hoist and find out those inserts are 180degrees off and the bracket won't fully engage.
  17. supersize75k5
    Feb 3, 2004
    8,832
    6
    gilbert az
    :doah:
    you just reminded me of a very very aggravating day I once had. Thanks for peeing in my cheerios:mad::p:
  18. 73k5blazer
    Dec 28, 2001
    5,126
    213
    The Rustbelt
    Build(s):
    I think we've all been there at one point. Not because of the mounts specifically perhaps, but just in general,
    "WHy won't it go all the down?",
    "How come it won't come all the back against the tranny?".
    " Why's this balancer touching the crossmember?"
    "Dude, You shouldn't have to beat those motor mount bolts in!"
    "Just a second, let me get a bigger pry bar."
    "WHy does the throwout bearing keep falling off?"
    All mixed in among many creative explicatives of course
  19. 73k5blazer
    Dec 28, 2001
    5,126
    213
    The Rustbelt
    Build(s):
    Installed the serpentine seutp I bought 3 years ago, I saw it at a garage sale for $100. I think GM sells the kit for quite a bit more.....
    It's almost to pretty. I should get a bucket of mud from out back and throw it on it.
  20. chevyuser74
    Jun 19, 2006
    1,473
    Mukwonago, Wi
    probably wont stay clean once its in i know mine didnt, but it sure did look pretty out of it.
