JACKBURTON55
Registered Member
OK let me preface this with I dont have a lot of offroad experience, so dont beat on me too hard but tell me how it is.
THE TRUCK:
78 K5, 350/350 with np203 with part time conversion kit.
INFO:
The transfer case pops out of gear if you dont hold it in, however, if hold it in, it will stay in 4hi lock, if i put the case in 2h, it will drive for a second, then slip and i hear this spinning noise and i can just rev the engine, no drive. The same goes for 2low. I currently have a redneck rigged job of chains holding the shifter in place.
Hubs were bad and missing parts, got some new warn premiums. just installed them.
THE ISSUE!:
I go to lock the hubs, and begin to drive off, truck is definitely in 4wd, and is pulling slightly to the right(is this normal? on concrete) I speed up ever so slightly and begin to feel something binding up, and then pops, as some kind of pressure is released. I stop, look under, everything is fine, and truck is still running. Put hubs in free, drive backward and what not, make sure they are unlocked, and park it and get on here.
SO what does this sound like? All the issues with my tcase and popping out of gear would have me believe it is the culprit with the 4wd not working. Thinking about it now, I dont think that 4wd on concrete is good, but this was a full time 4wd truck at one time right?
HELP, i want to fix it and go wheeling!
THE TRUCK:
INFO:
THE ISSUE!:
