i like that deal there. I have the ord and chicken saw how close it sits to the oil pan. good thing I own a engine hoist for changing the gasket
Im planing the ten till it breaks a joint or so and then move it to the k30 4 door for a tow rig and put cross over on it also seems a waste to have a 60 on a street pounder.(it was gone when i bought it)I see your putting in crossover on the ten bolt. Is the plan to keep that little thing with those monstrous tires?
I love the removable skins man. Reminds me of a trophy truck. The shock work is awesome and I love how much you did with so little welding.
Just a tip. If you moved that shackle flip hanger forward between 2-3in you'd get an ass load more droop. I dont mean to imply that you dont know this already but leafs are all about droop. They top out quickly from the spring rate increasing as they flatten out so the ideal way to get all the flex out of them is to set the shackle angle so they can just squeeze out all the up travel and leave the rest for a huge droop.
On the shackle i moved it about a month after the pics but the droop was not increased by much. The spring will only arc out so much, after that point when leafes start to seperate you are just asking for main leaf problems. There is also no weight on that tire or spring force so it did not seam to make sence to me. The pre runners do this alot and about half the travel is all shock and no spring rate. I can pull about 6 or more of up im thinking more like 8 from ride height. I see alot of guys on here set thier's up all droop and no up travel i went in the middle. I also read that the shackle angle should be at 45* with the main leaf flat for best results. And where ever the shakle is at ride hieght it just is.
Thanks for the comment i might try a differnt set up in the future but for now it works really well especially at speed so it will stay till i get the front done.
Here is the current shackle angle.
Ya all i did was reverse the bracket i set it so i could swap it around like the 56 swap right to left. It just sucks dropping the tank and skid plate to do it. Im looking into a 2.5 flip to lower the rear a couple inches.Yep thats exactly where I dialed mine into. The shackle tops out right when the springs are completely decompressed. It might be a little bit of an easier concept on a truck like mine where 4 leafs is plenty for the weight of the truck![]()
You know i believe its stock its an x forestrty truck but i seen a later forestry truck 88 at the junk yard with a 465/208 and it was a one piece. Maybe when they went slip yoke they went one piece.You have a two piece rear drive shaft? Is that stock? My 1988 has a one piece. I suppose beings you have an SM465/NP205, it is such a short combo, that GM put a two piece rear drive shaft instead of such a long rear shaft.
Martin
