My manual trans '79 K5 will not engage the starter when the ignition switch is in the start position. It acts like the clutch safety switch is not closed, which is not the case because a previous owner bypassed the switch. I'm guessing it's either the lock and cylinder or the electric switch. Possibly something with the wiring, but not likely. I've found my wiring diagram, and will begin troubleshooting tomorrow, maybe Saturday and have my son assist.
My question for the time being, which is more common to fail, the electrical switch or the lock and cylinder? I haven't had to replace either on either K5. Most info on the web is about replacing the cylinder, so based on that, the cylinder is most likely the issue.
