The power steering on my '79 has been whining (fluid topped off) and this week it started leaking, so I picked up a MasterPro from O'Reilly's last night. I also picked up high and low pressure hoses too. Last night I got the pulley swapped, no problem. I got the pump put on, primed the pump, no air in the system that I could tell. I got everything buttoned up this morning after messing with belt issues, unrelated to the P/S pump swap.
I started the engine, no whining, so that's good. I got in the cab to move the steering wheel...nothing. It won't budge. So first thought was I got the high and low pressure connections to the gear box reversed. Nope, that's correct. I loosen the hose connections on the gear box, start the engine and expect to see fluid squirting out from the fittings.... nothing but a drip. I disconnect the high pressure line from the reservoir body connection, start the engine and expect to see fluid gushing out. It's coming out, but probably just from the head pressure from gravity.
I'm thinking I got a bad pump from O'Reilly? Am I missing something??? It was kind of a no brainer to R&R, only one way to put it on, except for the hoses, which are connected correctly. I was wanting to get this done before the weather comes in this evening/afternoon. And with it being Thanksgiving most places are closed. I'm basically hosed, ha.
