8 inch lift shim question
TSewell
GA
I am going to install my 8 inch lift on friday. My TC is already dropped 2+ inches, would a 4* shim be adequate? What do you recommend? I know every application is different, but a good ball park figure would be nice. Thanks guys!
Sent from my BlackBerry 9780 using Tapatalk
Thanks for your suggestion. So maybee a different visual aid. What is the rear pinion suppose to look like, or what is a good or factory diff angle?
Not sure how a 8 inch lift effects the axles? I was under the impression that tires, gears, HP, and how you drive effects the axles, not the lift.
When I get home I will post pictures of my current pinion angle. I was told that the pinion angle and transfer case angle must be the same.
Here is a diagram i found online. What do you think? Is it correct? If so i would use a degree finder and messure my TC angle, then find my pinion angle, subtract the 2 and that should tell me how many degress to shim my axle. Correct?
Here is my current pinion angle with my 6 inch lift.
your pointing AT the t-case, so you must have a cv at the other end... just continue to point it at the t-case, down a degree or 2...
the equal angles are for non cv shafts...
LOL..No CV buddy....Just a custom length shaft.:whistle:
Just to be clear i did NOT put this lift on. I purchased the truck like this. I have never shimed a axle before so i had no idea where to even start.
The proper angle depends on whether you have a CV aka double-cardan driveshaft, or not.
With a single U-joint at each end, then you want the split the angle. This may result in very high angles on the ends, if you have a short shaft and/or a great distance between the T-case and axles, i.e. crazy high lift. In this case a CV shaft may be called for.
If you have a CV at the one end, then you want the pinion pointing straight at the shaft, as you have pictured.
Google is your friend... try these for starters:
http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml
http://www.4xshaft.com/driveline101.html
http://www.pirate4x4.com/tech/billavista/PR-shaft/index2.html
The answer for your specific case is you need to measure your specific truck as each case is different. And you may need to change to a CV shaft.
-- A
