What bushing are you running in the rear hangers?
Ive thought about that. If I run into issues I'll try a panhard bar on the rear and see what it does.Get those fronts working good and that thing is gonna be awesome.
I like flex joints in the rear suspension but I know a couple guys who have complained about some shifting.
Interested to see how you like em
They are trail gear creeper jointsWhat bushing are you running in the rear hangers?
Here's a few of the front driveshaft to bellhousing clearance. I'm interested to see how close it is when the front flexs.That would be great. Thanks man!!
Thanks! Tcase is in the stock location and they are 4in lift springs right now. Not sure how much up travel it will have when I do the 52s.Pssshh, looks like plenty of room. And you said 4" lift right? Thanks for the pic. Did you clock your tcase at all or is that in the stock location?
I'm really liking this build BTW...keep up the good work. I like your rear inboarding!
Haha yeah what a mess! Lol the quality of his work is a direct reflection of his shop condition.It would move along faster if you cleaned that shop up a little.... Shhheessshhhh.
Nice build!!
Everything on it is AN6 lines. I used adapters at the fuel rails, push on lines and fittings from the rails, aluminum hard lines along the frame, and then flex line to the fuel cell.What did you use for fuel lines? Factory take-off's or did you go aftermarket flexible?
Yeah I'll build a anti wrap bar for the rear. It's going to have a tube flatbed similar to ORD's cousin WillardCute tuner.
Are you going to build a rear traction bar?
Put box sides back on it.
Martin
