Never pass up on those pedals. Somebody always wants them if you don't need them.
Otherwise good work to get the truck moving.
. But when I can't find the correct pigtail and I'm finding other wire corrosion. So this should fix that issue.
. Probably something stupid. They had been working.
Lock washers?
. I should be able to find them in stainless.All the big trucks run studs with spacers and pinch nuts on manifolds. Any room to do something like that on this spacer? I'm betting it's coming loose from the expansion and contraction with the heat cycles.
I like Nylock but not in higher temp situations. deformed nuts work well and the serrated head stuff works pretty good. Split lock washers are garbage NASA has videos of how they loosen up under vibration. I'm a fan of Nord Lock's as they actually take more to break loose than the torque achieved.I had them on the setup that fell out. The split ring style. Maybe the serrated style would work better. I should be able to find them in stainless.
I need to find a new driver side seat belt too. It retracts fine but the belt it self is getting frayed and crinkled. Making it hard to pull to latch.
Anyone selling a good set of blue seatbelts?
Oil supply pressure is also very important. Now the engine had 10psi at warm idle. 25psi running a 1500rpms.
You have 10psi of oil pressure?![]()
On the cheap mechanical gauge that is "T"ed into the oil supply for the turbo. The stock dash gauge reads higher. But not sure how much I trust that one.
Minimum according to GM is 1psi per 100rpms. So 10psi at 600rpm idle is almost double that. And it increases are rpms increase. So it seems low but it's being consistent, so far.
That seems way too low. I'm not an expert, but I have had 7 of these engines. Mine have all held at least 50PSI on the dash gauge at idle (some of them more). I'd get pretty nervous if it dropped that far.
Are you measuring downstream of a restrictor plate?
Where he’s measuring it I wouldn’t be that worried, it’s not like the turbocharger adds enough restriction to the oil feed line to register much pressure
My concern was for the lower end, if that represents the pressure in the block. The normal 6.2 turbine oil port is pretty near the gallery where the stock oil sensor sits, and they're both measuring the oil just downstream of the filter housing. So the readings should be fairly similar, unless he's downstream of a flow restriction.
Have you ever checked any of those with a mechanical gauge? I'd be curious as to how it compares
