K5trs
Well I'm starting a new thread to actually start my (slow) build. My first question, what do i do first? After some bad news i believe my engine is only a 305, still not for sure because I don't know how to check. How underpowered are they? It runs good and appears to have been rebuilt, I won't be taking it through anything crazy just some mud and maybe the occasional dune trip. Do you think it can handle that? What should I focus on first? Swapping in a 350? Maybe Re-gear, and axle swap (Which i know almost nothing about either). Maybe I should lift it and put on bigger tires? Also part of the reason I bought this Jimmy was to learn about mechanical work, so I'm not afraid of working on it myself.
As you can see I'm a little lost/overwhelmed and i would like all of your opinions on what I should be starting with. I trust that with all of your unlimited knowledge you guys can give me a good starting point. So go ahead and give me advice all is appreciated!
) And despite not being very mechanical, by the time he was done, he was swapping in a ford racing 302 engine with me just helping him via phone while i was at school in Vermont.
) short block later down the road. Alot of people will bash the 305, especially if you need the HP to do dunes and mud, but its a solid starting point. and will motivate the truck while you sort the rest of your plan out.
