Suspension pre-test and cycle…
Well, after many many long hours I got to the point where I could test and cycle the suspension as it was tacked in. I got the tie rod and drag link made out of one piece 1.25 x .250 DOM threaded on the inside from ORD per my custom order. I purchased the bent draglink for better tie rod end angles and frame clearance, and at full droop the tie rod ends are barely clearing (if I try to turn the tie rod straight it will then start to bind). I got the track bar mounts finished up but after cycling the thing and articulating it I had to move it, AGAIN. So many things had to be tested and retested. Especially at the passenger side where the pumpkin, tie rod, track bar, drag link, shock mount, and upper and lower control arms all come into the same area. Not to mention you need to fit bumpstops in there. I also have my custom engine crossmember all tacked and ready for welding. Including bracing for the engine mounts, and mounts for the air bump stops. When you combine the cycling up and down, articulating, and steering all at the same time it gets pretty crowded in there! It all looks simple now but there are many things that come very close when everything happens at the same time.
My friend Jer (dune jump)came over and helped me bend up some shock hoops and an engine crossbar, awesome, Thanks Jer!
Anyway, at this point it was countless hours of work and rework of some things for clearance. I initially planned on using a ballistic joint at the track bar axle end, but had to change to a rod end with high misalignment spacers to get more room for the draglink. Just remember to tack things in place and don’t weld it all up until EVERYTHING is done and cycled, because you will thank yourself!
My track bar is not perfect, I wanted the exact same length and angle as the draglink (you can’t count the bend, just from pivot to pivot). Anyway, I ended up with a compromise of what I wanted and what I could get to clear everything. It works great, and I don’t notice any bumpsteer. When I thought about it, it had to be better than it was before because before the leaf springs were traveling straight up/down (from a side/side standpoint), and the draglink was on a sideways arc. Now they are both on a similar arc, just not exactly the same.
In testing for articulation I didn’t have any springs on obviously, and I removed one upper arm so there was zero bind. I got 20 degrees both directions when each shock was bottomed out for 40 degrees total articulation travel. Since the tires are outboard it travels more than I expected with the 14” shocks (which is why some brackets had to be redone). Articulation testing...
Here it is dropped until the shocks are bottomed out. I still need to add limit straps, I couldn’t order them until I knew the length I needed. You can also see how the driveshaft angle remains almost perfect (I have it angled a couple degrees up since it will want to pivot down under torque in the front). I ended up with a degree or two extra caster(at ride height I have about 9 - 10 degrees) since my estimations/measurement with the Dana 44 were off from when I actually got the Dana 60 in and located, but that's all good anyway. A little extra won't hurt anything, too little would be very bad.
So after that I had to measure some more check everything, and then test with the tires on (holy crap did the tire stuff into the wheel well, was colliding with the piggybacks darnit).
Also, I originally moved my axle 2" forward, but because the axle pivots up and forward now (instead of up and back), the tire was crashing into the front fender when it was straight, let alone turned left/right. So I moved it back an inch (1 inch ahead of stock), and still trimmed the front fender all the way too the inner fenderwell/core support.
I also had to move the steering intermediate shaft yet since the coil spring was going to be hitting it during articulation. And I was running out of time for the trip, so junkyard runs were out of the question.
Then tear it all apart, weld it, add more bracing and tubes, and assembly everything for the final time (the best part).
Any questions about why something looks stupid or how something works fire away.
