84 cucv m1009 “greenmeanie”
Average User Rating:
5/5,
  1. America.Mike
    America.Mike Blazer bash or bust! Premium Member
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    America.Mike submitted a new Build:
    America Mikes 12v cucv build
    Read more about this build here...
  2. obijuank5
    obijuank5 1/2 ton status Premium Member GMOTM Winner
    Jul 3, 2016
    3,727
    6,749
    Build(s):
    Glad to see you start a build thread here. I've enjoyed seeing the posts on the cummins swap groups.
    Fastereddie and America.Mike like this.
  3. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    Thanks man. I’ll try to edit and put the build in order when I have some more time.
  4. Fastereddie
    Fastereddie Sorry if I offended you. Not. Premium Member GMOTM Winner
    Aug 6, 2016
    3,582
    6,009
    Henderson Nevada
    Build(s):
    Yeah looking forward to pics and updates !
    America.Mike likes this.
  5. ZooMad75
    ZooMad75 #crawlabago Premium Member GMOTM Winner
    Apr 5, 2003
    4,280
    7,480
    Pueblo, CO
    Build(s):
    Looks very clean and detailed so far. Need to see more!
  6. onetonbb74
    onetonbb74 On the rocks... Premium Member GMOTM Winner
    Dec 1, 2005
    2,668
    1,205
    Coyote, CA
    Build(s):
    Great build! We need more pics!
  7. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    Thanks everyone! I’ll get everything updated soon with more build pics in order of build.
    GoGoGirl likes this.
  8. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    Humble beginnings. A little over a year ago I Removed frame , fixed floors , bedsides and inner /outer rockers, and Blasted frame and brushed two coats of por15 on it. 399D1BBD-C0E9-4D35-990B-A3C5D96AD2E6.jpeg 7560790C-936B-4B26-8FBE-114B50EC3BFD.jpeg 38A21E1A-669B-4BF7-A948-018EED4EFBF9.jpeg FE16AAC1-0CDE-4ED5-B1DF-569B5350F1B5.jpeg 7A676A72-1BDC-4C6D-A740-55E24673299C.jpeg
    530BLAZER, KirsL, Capt Ron and 2 others like this.
  9. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    FD53FBBE-2CB5-415E-A6E6-8A9F5A03652D.jpeg After the frame was finished I started bolting suspension parts on. 48414B49-8D75-4416-977E-D0F0776FBEC0.jpeg
    530BLAZER, K588 and Fastereddie like this.
  10. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    Once that was done I started prepping the undercarriage for upol raptor. Then sprayed upol acid etch primer and 2-3 coats of raptor liner. 369D44B4-3E34-41BC-8EFF-D1360D9C4988.jpeg 3FCCAE40-4586-4372-B4E1-B88A052106F5.jpeg
    530BLAZER, GWeakland620, K588 and 3 others like this.
  11. nvrenuf
    nvrenuf I grind my welds. Premium Member
    Jan 7, 2002
    17,202
    4,050
    Mobile, Al.
    Build(s):
    Glad to see this, I’ve been following it on IG. :pimp:
  12. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    After a week of letting raptor cure I mounted the body to the frame
    8ED3510E-8615-4D09-B6F1-DF6537CF8C52.jpeg 60C2D237-BD4B-40C0-B794-E353563EC038.jpeg 65A8083A-0687-473A-B5C3-B75290C50883.jpeg
    530BLAZER, 72gmck5, KirsL and 3 others like this.
  13. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    Once the body was mated to frame I needed to start working on the engine and transmission before installing. The Dodge nv4500 Transmission was shot so I did a full rebuild ( all new parts including gears) and swapped a Chevy main-shaft and tail housing in it.
    E376074C-A5D0-4F9B-88B0-C9D3C07FE9BA.jpeg BB8F5D86-6CA4-43E9-AE22-11FC614989F6.jpeg 088572DB-B7ED-4175-AC52-A5C1B1E22D60.jpeg E9E385FB-B8FC-409B-A2EB-026F00CE5811.jpeg F2C53609-1F21-412B-83A3-AA92019263AB.jpeg
    530BLAZER, K588, onetonbb74 and 2 others like this.
  14. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    Onto the engine. I purchased 1998 Dodge Ram with a 12v as the donor truck. Got it dirt cheap with low miles. Body was shot like everything else in the rust belt lol. I pulled the motor and started working on it as soon as it was on the engine stand. I replaced all the gaskets with factory Cummins parts. I also went through the p pump , installed some goodies including injectors, modded the gov spring and fuel plate. Also installed billet freeze plugs , and killer dowel pin fix.
    56A3DD14-01E0-4269-B5F3-E07CC5C1E4A5.jpeg 6D6F0BEA-C734-4B94-99DE-805FACF06CF3.jpeg C1A2D57E-882C-48B8-B887-76BDE8D66E5D.jpeg
    530BLAZER, K588, Fastereddie and 2 others like this.
  15. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    Once the engine was ready I couldn’t wait to get it in. My brother came over to help since we were installing it with transmission bolted on .
    3F17C75B-20D6-490E-B048-E81BBA58E1C5.jpeg 0F75913A-CD14-41DD-BE87-788FA896129F.jpeg 07A82B8C-B304-47EC-9C84-C73308DCC538.jpeg 4ED0C564-593F-4098-9F20-96368BBB8E9A.jpeg
    530BLAZER, K588, KirsL and 5 others like this.
  16. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    Fuel system up next! I replaced all the hard lines and install Larry bs high flow banjos and deleted the Fuel heater while I was at it. DFC232AF-0639-4176-84DC-3B546ED4E5CB.jpeg E962D70E-2821-4785-B6AC-B982436636B4.jpeg B233C158-1EB3-4BCC-A12E-7C7ACE20E51D.jpeg
  17. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    Purchased some rock rings and welded them on the h1 24 bolt beadlocks
    AD47C4C5-245E-438F-BE3F-C4641EA9210D.jpeg 067D9F85-E7A7-4911-937D-62D976360F26.jpeg 32102BA9-E9F6-42D0-A586-1CBFE5168C3F.jpeg B7035E06-96F6-4FA7-A31A-C84AE675DF72.jpeg 72BD0A4D-8C60-4725-8E40-A3FC45A550F7.jpeg 51751C5F-DC61-4FA0-ADBC-7C986C73D45E.jpeg
    530BLAZER, GWeakland620, K588 and 5 others like this.
  18. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    Once the wheels were finished I needed to upgrade and rebuild axles. The front Dana 60 axle was from a 1980 drw c&c. The rear 14b was from a 1980 van. I installed Yukon 4.56 gears, 35 spline Yukon front chromoly axles , yukon 35 spline hardcore hubs ,Yukon grizzly lockers front and rear , and 14 bolt disk brake conversion.
    AFA1582B-6B83-440F-8775-B5081138762B.jpeg B083D26E-F895-480E-AE1F-BE9A4D6D4A4E.jpeg 9EE46304-23EC-4B0A-8E10-4DCCBCC7B04C.jpeg 03BEA48A-973D-4926-AF11-E839578EEE06.jpeg 10BF5686-AFBA-492B-BE10-F97E7A4162D5.jpeg
    83DA7166-1BA3-4F72-895D-0156FD0752E9.jpeg DFB989CE-8BBB-478A-9614-6986BC8480DF.jpeg 09229E51-7621-42B6-96E4-ADB63982C9D8.jpeg 5907B77F-0043-4436-9043-94A5CD908AD4.jpeg B820C92D-1E37-45DE-B18A-E13FB51C6542.jpeg F77B0294-1E14-4423-BC35-CBAA035DCB5D.jpeg
    530BLAZER, K588, onetonbb74 and 3 others like this.
  19. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    Then prepping and paint AD27138C-37C3-45EF-858A-AC240359D3B7.jpeg 333AB0CB-9DB7-4609-8940-921445EF40E3.jpeg
  20. America.Mike
    Mar 29, 2019
    155
    348
    Iowa
    Build(s):
    I wanted my dash to be removable. So I welded dzus fastener tabs to body and riveted the fasteners on the dash before painting black
    86A98C17-CE5F-4D61-87FB-C15BBBA8EA61.jpeg 60750080-AC76-417C-9BAE-DEF90D23C6CE.jpeg A0673FAD-3E41-49BC-AE23-FEE42AEA5D0D.jpeg 82EA76A9-EFD0-4B10-A992-765C04C76C18.jpeg DFD9081B-8466-490E-9ADB-645ECC3589EA.jpeg
