'84 K10 White Lightning
Average User Rating:
5/5,
  1. skunked
    skunked in the garage Premium Member GMOTM Winner
    Feb 27, 2013
    11,427
    10,626
    Placer County CA
    Build(s):
    31 gallon
    7.25" at the point below, let me know if you need any other measurements. The frame isn't flat so it measure less toward the rear and more toward the front.
  2. mrk5
    Apr 20, 2004
    14,693
    3,854
    Northern Colorado
    Build(s):
    That's good enough. I was mostly curious. Still thinking I'll end up with a K5/Burb tank in mine too.
  3. skunked
    Feb 27, 2013
    11,427
    10,626
    Placer County CA
    Build(s):
    my only advice is not to mess with the 25 gallon tank, that was a waste of my time with a thirsty BBC. Hopefully the EFI helps a little too.
    mrk5 and F.S.F.W like this.
  4. F.S.F.W
    F.S.F.W Caught up in the movement Premium Member
    Feb 9, 2016
    7,068
    7,000
    Douglas Wyoming
    Build(s):
    Sorry if you mentioned it already but what did you use for the tank skid frame?
  5. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    11,667
    1,708
    Hooper, Utah 84315
    Build(s):
    3
    It has to get around the leafs to get there also
  6. skunked
    Feb 27, 2013
    11,427
    10,626
    Placer County CA
    Build(s):
    I don't think I mentioned it
    1.5" .120
    The shackles/leafs are going to provide some protection in some scenarios but not enough for the wheeling I plan on doing.
    bmxbryant9 and F.S.F.W like this.
  7. truck-oholic
    truck-oholic 1/2 ton status Premium Member
    Jul 18, 2014
    1,100
    495
    Spring Hill, TN
    Build(s):
    Bout time you got something done on this :rotfl:
    bmxbryant9, skunked and F.S.F.W like this.
  8. F.S.F.W
    Feb 9, 2016
    7,068
    7,000
    Douglas Wyoming
    Build(s):
    Sweet. Don't copyright it.
    It's amazing how pointy rocks will find their way into places they don't belong. Fence posts and logs do the same thing. I scratched the bottom of my cab and busted the slip yoke housing off my 241 with a slab of concrete once too.
  9. skunked
    Feb 27, 2013
    11,427
    10,626
    Placer County CA
    Build(s):
    Don't you have an Isuzu to work on? :flipoff7:
    Copy away. Might want to wait and see if I can break it first.
    And your right about the logs and rocks and wierd shit working its way into the wrong areas. I'm more worried about those rock gardens.
    NorCal69, bmxbryant9 and F.S.F.W like this.
  10. truck-oholic
    Jul 18, 2014
    1,100
    495
    Spring Hill, TN
    Build(s):
    Geo Tracker Bash 2017 here i come, wait, wrong forum, sorry :D
  11. Jumppr
    Jumppr 1/2 ton status Premium Member
    Dec 9, 2014
    129
    61
    Clovis, Ca
    Build(s):
    I've been thinking about skid tank fabrication for mine as well. One thing I've been considering, since I want to run the 31 gallon tank, is can the top of the frame be modified some so as to raise the tank? I'm sure You'd need a body lift for this. It looks like you're giving up a few inches of GC with that design and maybe you wouldn't have to if you could go up with the tank at all?
  12. skunked
    Feb 27, 2013
    11,427
    10,626
    Placer County CA
    Build(s):
    This was something I considered, posted pics and discussed earlier in the thread (few pages back). The tank would need to be modified a little or the frame rails would need to be trimmed. In the end I was losing bed space and gaining unusable space under the bed. Just didn't make sense....
  13. Jumppr
    Dec 9, 2014
    129
    61
    Clovis, Ca
    Build(s):
    Sorry.....I've been reading backwards and just got to the part where you're trying to figure this out. Plus, I forgot you're working on a truck and not the K5.
    skunked likes this.
  14. GWeakland620
    GWeakland620 THE CK5 Crayon Eater Premium Member GMOTM Winner
    Sep 15, 2010
    11,027
    8,279
    Toe-peek-ugh, KS
    Build(s):
    3
    I like it. It's leaps and bounds better than a factory located blazer tank, and you have plenty of protection if need be. Plus saving the bed space is nice.
    UpnAdam and skunked like this.
  15. skunked
    Feb 27, 2013
    11,427
    10,626
    Placer County CA
    Build(s):
    Boxed the back of the frame on either side of the gas tank.
    Then I moved onto the muffler which i needed to add hangers/brackets to secure it. After burning in the first bracket/hanger I realized the exit was about 2" from where the shock would be. So I moved the muffler about 8" forward, added a couple crossmembers and brackets for the hangers to mount to. I'm pretty happy with the outcome.
  16. GWeakland620
    Sep 15, 2010
    11,027
    8,279
    Toe-peek-ugh, KS
    Build(s):
    3
    Looks good dude!
    skunked likes this.
  17. mrk5
    Apr 20, 2004
    14,693
    3,854
    Northern Colorado
    Build(s):
    Nice!
    I've been thinking about the straps you added above the gas tank. I don't remember anything on top of my K5's tank, is that something you did for good measure? Or?
    And this is the first time I noticed you have a DIY4x Wraptor. :waytogo:
    skunked likes this.
  18. skunked
    Feb 27, 2013
    11,427
    10,626
    Placer County CA
    Build(s):
    That's correct, the original k5 design doesn't use straps on top. That's something I came up with. I'll add some anti squeak material between the upper and lower straps and the tank during final assembly.
    And yes, that's Kerts anti-wrap and back bone setup. The crossmember that came with the kit isn't being used, with the added doubler length I had to go a different route.
  19. mrk5
    Apr 20, 2004
    14,693
    3,854
    Northern Colorado
    Build(s):
    I was just thinking about my laziness and if I could skip that step.... :whistle:
    I envy you being able to remove your bed to do this work.
    skunked likes this.
  20. skunked
    Feb 27, 2013
    11,427
    10,626
    Placer County CA
    Build(s):
    You could use the k5 crossmembers which will hold the tank, lower straps and I believe the stock skid plate. Removing the bed is worth the time If you can.
