'84 K10 White Lightning
Average User Rating:
5/5,
  1. mrk5
    Apr 20, 2004
    14,694
    3,856
    Northern Colorado
    Build(s):
    I tried pulling the bolts but they are stripped out in the bed. With the bed floor covered by 1/2" of uncured roofing tar or sealer I'm not messing with it until I'm swapping on a different bed.
  2. 6872xtc
    6872xtc make mine modified Premium Member GMOTM Winner
    Sep 16, 2008
    3,001
    1,830
    Palisade,Colorado
    Build(s):
    I have welded the heads of the bed bolt to the floor on a couple trucks. Then I don't have to find many replacements.
    mrk5 likes this.
  3. skunked
    skunked in the garage Premium Member GMOTM Winner
    Feb 27, 2013
    11,483
    10,677
    Placer County CA
    Build(s):
    yeah that's no fun.
  4. brokenparts
    brokenparts 1/2 ton status Premium Member
    Mar 11, 2011
    633
    459
    hillsboro, or
    Build(s):
    Looks great!
    skunked likes this.
  5. skunked
    Feb 27, 2013
    11,483
    10,677
    Placer County CA
    Build(s):
    Received some goodies from summit today. TH400 dipstick, Derale PS cooler, locked out MSD distributor, MSD coil & bracket, fittings and the wrong daystar bumps. Hoping to finish the frame boxing this next week.
    F.S.F.W, max 02, truck-oholic and 7 others like this.
  6. mrk5
    Apr 20, 2004
    14,694
    3,856
    Northern Colorado
    Build(s):
    Yay for boxes of parts!
    skunked likes this.
  7. skunked
    Feb 27, 2013
    11,483
    10,677
    Placer County CA
    Build(s):
    It was a good box of stuff, bunch of parts that I've known I needed for a while and just sat on my wish list at summit.
    Also ordered the correct Daystar bumps last night with the single stud mount configuration. Those should pair up nicely with Kert's adjustable bump stop brackets after I fab some platforms off the spring plates.
    83ChevyK5Blazer likes this.
  8. skunked
    Feb 27, 2013
    11,483
    10,677
    Placer County CA
    Build(s):
    Pulled the 205 this morning, trimmed the adapter so the JB Fab hardware will clear the plate. Also drilled holes in the NWF mount/foot so it's clocked correctly.
    Messed around with the front bumps
    F.S.F.W, max 02, bmxbryant9 and 3 others like this.
  9. truck-oholic
    truck-oholic 1/2 ton status Premium Member
    Jul 18, 2014
    1,100
    495
    Spring Hill, TN
    Build(s):
    Looking good. Is the flat head hardware behind that foot not needed or just not installed?
    I might have to get out to the garage later today and do some blazer stuff to start 2017 off right.
    skunked and 83ChevyK5Blazer like this.
  10. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,532
    3,207
    Dallas
    Build(s):
    Great, clean looking work.
    David
    skunked likes this.
  11. GWeakland620
    GWeakland620 THE CK5 Crayon Eater Premium Member GMOTM Winner
    Sep 15, 2010
    11,066
    8,313
    Toe-peek-ugh, KS
    Build(s):
    3
    Looking good.
    skunked likes this.
  12. skunked
    Feb 27, 2013
    11,483
    10,677
    Placer County CA
    Build(s):
    It was just mocked up in that pic because I needed to shoot some paint on it still. I'm hoping I don't need to mess with these parts again.
    And yeah you need to work on the K5.
  13. skunked
    Feb 27, 2013
    11,483
    10,677
    Placer County CA
    Build(s):
    Tapped the cover with a 3/8" NPT fitting for a fluid sight. Need to order more fittings, it's amazes me how shitty the selection is at home depot and lowes these days.
    Adapter and foot painted and installed
    And the other mount modified for the JB Fab cable bracket and painted
    F.S.F.W, bmxbryant9, Bent77 and 3 others like this.
  14. skunked
    Feb 27, 2013
    11,483
    10,677
    Placer County CA
    Build(s):
    Does anyone know where I can find these poly donuts with the sleeves?
  15. skunked
    Feb 27, 2013
    11,483
    10,677
    Placer County CA
    Build(s):
    Welded nuts to the FUSH hangers and boxed the drivers side section.
    F.S.F.W, max 02, bmxbryant9 and 4 others like this.
  16. mrk5
    Apr 20, 2004
    14,694
    3,856
    Northern Colorado
    Build(s):
    Funny you post this, I was thinking about the exact same mounts myself!
  17. wetoolowdingbangow
    wetoolowdingbangow 1/2 ton status Premium Member
    Nov 30, 2014
    4,617
    2,917
    East Bay, Ca
    Build(s):
    Those look a lot like these:
    https://m.summitracing.com/parts/ens-9-4102g
    I noticed daystar will allow you to enter dimensions on their site and they'll find you a poly mount. Summit had a ton of universal ones too.
  18. skunked
    Feb 27, 2013
    11,483
    10,677
    Placer County CA
    Build(s):
    I'll make sure I share the part number once I find them. I've seen them used several times so I know they're around.
    I played around with that, ordered the ones I found and then summit cancelled my order claiming daystar didn't have them any longer. The ones you posted are too big. I'll keep looking.
  19. nvrenuf
    nvrenuf What update?? Premium Member
    Jan 7, 2002
    14,378
    1,302
    Mobile, Al.
    Build(s):
    Take a look at these Energy Suspension bushings.
    skunked likes this.
  20. skunked
    Feb 27, 2013
    11,483
    10,677
    Placer County CA
    Build(s):
    nvrenuf likes this.
