84 Torque Converter Clutch Wiring
TerryD
Mildly demented...
Covington, Va
I was wondering if anyone has a diagram with wire colors for the factory torque converter clutch wiring. I'm looking at reworking it a little, but would like to use the factory wiring to set up my system as much as possible. I've been searching online and looked in the Haynes manuals at the local parts stores, but they don't have anything in them.
What are you trying to change? I am very pleased with my BTO setup, since I got rid of my CC carb and computer. Just saying, was easy too.
I want to do what the BTO kit does. I just need to know where the factory wires go to know what and where to hook into them.
factory wires that control lockup go into the driver's side of the transmission case. The factory plug has two or three wires going into it. The BTO kit only has one. There are also some wires going to the brake switch mounted under the dash and is controlled by the brake pedal. It causes the lockup to disengage when the pedal is pressed. Depending on your year 700r4, or if you have a computer in the blazer, you will have other wires coming from the passenger side of the transmission going to the computer (IIRC) and maybe something coming from the brake switch. I can't remember.
The BTO kit has a new piece that goes into the trans, from the pan, I believe this is was controls the pressure to the lockup, it is powered from the wire going into the driver's side.
It's been a while since I installed this stuff. I don't remember the details, but it works well. As soon as the trans shifts into 4th, it is locked. If if step on the brake pedal, it's unlocked and depending on speed, either stays in 4th unlocked for a few seconds, or drops to 3rd.
