Dawson Clawson
1985 K5 Silverado 4x4.
5.0L 305hp
Sparkplugs, wires, and Distributor cap/rotor we already changed.
The carb is an original quadrajet, from what I've been told. Haven't IDd myself (not sure how, exactly - I'm car-tarded). I've already taken it to the mechanic to unstick a power valve and change the EGR valve. They sprayed some solution in it and let it sit overnight. It runs much better at idle and cruising speed.
However - If I'm sitting at a full stop and depress the gas pedal to give it a teensy weensy bit of gas, the K5 hesitates like it isn't hearing my foot. Just really slightly. If I give it a bit more, it does better - no hesitation. It did this before I had it fixed, was fine for a week or so, then back to what it was before.
The mechanic told me that it's most likely the best I'll get without replacing the carb. Doubtful to effectively troubleshoot over the webs, so I guess I'd like to know what would be the best carb to install?
I've read here that Quadrajets were the best carbs for 4x4 Blazers. Would that be the case? I don't go off-roading yet. I don't race myself down city streets. I'm a pretty conservative driver since I'm still fixing issues as they arise.
Lastly, I'm more interested in a clean running truck than I am horsepower or gas mileage. I just want it to purr at rest and go when I tell it to. Not pussyfoot.
Thanks for your help!
5.0L 305hp
