I will try to keep this short and sweet. Have an 87 K5 with 700r4. Trans went out in it. My buddy has a guy that runs a tranny shop. Got a rebuilt 700r4 to swap in and fix my issues. Got the old one out and new one bolted in and ready to test drive. Here's where the problem is. Also keep in mind, I am pretty clueless to the internal workings of transmissions. Basically when I shift from drive to reverse, down to neutral then overdrive that's where the shifter stops. It won't go down to drive, 2nd or 1st. Climbing under the truck you can manually shift through all the gears on the trans. Here is what is puzzling to me. When the shifter goes into neutral the reverse lights are on and it seems like when the shifter is in the park position that the trans is in overdrive. I am completely puzzled by this. Could the gears have been installed out of wack when it was rebuilt? I am clueless about trannys but will try any advice anyone can provide and will do my best to supply pictures or whatever if need be. I appreciate any info or help. Thank you CK5ers.
