87 k5 fender flare help
Tyler Hart
Registered Member
PENNSYLVANIA
Hello, I've been reading the forums about different ideas tried but nothing seems to be quite what I'm looking for.
My truck is an 87 K5 with a 6in. lift and Im running 40/16 Super Swampers on a 16x10 Beadlock.
I purchased a set of Bushwacker cut out flares and installed them, and the tires will clear fine but not on the trails. Has anyone encountered this problem and found a solution. Is there anyone who has made a set of tube, or steel flares? Can you purchase and use a set of the rear cut out flares on the front for more clearance? I drive the truck on the street so just trimming the fenderswithout the flares isn't an option, Ineed the flares for inspection.
Any help would be greatlyappreciated.
