Midwestern4x4Parts
It is a Great Lakes Off Road Cover. One of the Best on the Market in My Opinion. Won it on Pirate in a Vendor Giveaway.
ROXROES said:C's are rotated about 6-7 degrees. Pinion angle will be in the ballpark of 15-17 degrees. Putting the front axle back together, roll it under the truck check everything out. Bring it out weld c's.
Then I'll get the links all mounted up, wheelbase set etc.
Then I'll get the full hydro done and airshocks mounted. Trac bar will be last, going to make it as long as possible and as level as possible to prevent jacking.
Philip, definitely glad we're going with a 3 link. Its going to get you a ton more downtravel, and keep the driveline much happier.
Ok Answer's to your questions. There are no U bolts in the back. It is a U bolt less Spring Perch. The Bolts hold the leafs in.
. There is a reason that the OEMs use u-bolts
That's pretty scary. If you had a lot more wrap around on the perches and they were welded on both sides, then maybe I could be comfy with it, but the way it currently sits.... I've seen way too many shock mounts with equivalent weld area and less loading torn away from the axle tubes during wheeling adventures to have much faith in that setup. There is a reason that the OEMs use u-bolts
Just gotta keep an eye on the bolts.
dude i dig it. bring on the new ideas!!!! with out trial and error everyone wouldent be runnin 52's and 56's up front or 64's in the rear. somone tried it, it worked now its the norm. same with the shackle flip. yaanaadadameeen?I wish more people on CK5 were open to different Ideas
It's not scary. There are a few company's that market U bolt less spring perch's. I don't think they would sell if they were uncomfortable with the risk's.Me I was being a cheap ass and didn't want to spend coin on U bolts. As I said it will be linked pretty shortly in the back when the front is done. Already have the parts needed. I wish more people on CK5 were open to different Ideas.
Times change and there is a time you accept it. This is just different from the norm. I guess if you wanted to think. If That is about the most questionable part on my truck I can deal. I hear comments about it quiet often though. Only regret I have is not having it wrap more.
a weld on the axle tube doesent twist or bend at all so you shud be fine. my only concern would be how thick the bolts are. if you welded it with 70,000 pound rod or better you will be just fine.
