Wanted 89-91 Quad headlight parts
TommyD11730
NY
Hey guys looking for the parts to convert my 84 GMC K2500 to a 89-91 nose. I'll consider anything that you have. From a headlight bucket all the way up to a donor truck. Thanks for looking!
Photo to show what I'm looking for.
Are you still looking for a grill? I still have a complete quad headlight clips still on an 89 Blazer.
Tell ya what I could use. A harness. I got one but it's really short. Would love to have one from the junction block forward.
Not sure what harness you are referring to but if you could send a picture I’m sure I could get it for you off the truck
Headlamp harness. I have one, but the PO cut it a foot or so behind the DS of the support. Would like the entire harness from lamps to firewall plug.
Thanks.
I want to make sure I know what you are taking about. The wire harness that one end plugs into the front driver side headlights and runs along the top of the drivers inner fender well and plugs into the firewall on the other end by the brake master?
it also goes out and across the front lower core support to the pass side .
I may have all the buckets with the springs. They are in a box from when i bought them off someone about 10 years ago. I can check this weekend.
I do have everything in @foylinj suburban as extras, but he hasn't decide if he wants to give them up.
Mine rig is still in the air if I'll swap back to the vertical dual light
