89 Suburban is gone....added a K5 in it's place
Discussion in 'The Driveway (build threads)' started by Desert_K5, May 21, 2017.
  1. 1-ton
    Apr 17, 2004
    3,332
    455
    Las Vegas, Nevada
    Build(s):
    That looks like a nice truck. It has a Vortec small block in it assume.
  2. Desert_K5
    Desert_K5 1/2 ton status Premium Member
    Apr 23, 2016
    268
    233
    As I'm pulling the door panels out of the donor I realized I do not know how to disconnect the power window switch? It says twist to remove but it keeps spinning? The dumbest things hang me up sometimes, and this is my first one with power windows I'm taking apart. Any help?
  3. Fastereddie
    Fastereddie Sorry if I offended you. Not. Premium Member
    Aug 6, 2016
    877
    1,034
    Henderson Nevada
    Build(s):
    Its a cheezy twist off. You have to pull it off as you twist. Sometimes pretty hard. Its one of those tinnerman push on things.
    Desert_K5 likes this.
  4. max 02
    max 02 N.E.D. Premium Member
    Sep 29, 2009
    9,171
    2,060
    Clive Alberta Canada
    Build(s):
    Looks super clean!
  5. Desert_K5
    Apr 23, 2016
    268
    233
    Yeah its in excellent shape for a 91. Heavy half ton model with a 170k on the clock.
    sreidmx, max 02 and AbramJ like this.
  6. Desert_K5
    Apr 23, 2016
    268
    233
    Are you guys that run the hubcaps using the stock steel wheels, and if so how wide of a tire are you running?
  7. Fastereddie
    Aug 6, 2016
    877
    1,034
    Henderson Nevada
    Build(s):
    You remember my brothers old blue 2wd?
    He was running 33x12.50-15 on those stock width wheels. I personally wouldn't go wider than 10.5, but you know what that truck went through:woot::burnout:
  8. Desert_K5
    Apr 23, 2016
    268
    233
    haha yeah. I have 315 75 16's on everything else I drive and figured why not if they'll fit.
  9. Desert_K5
    Apr 23, 2016
    268
    233
    Still wish I had the black pre-runner, except the half dozen transmissions and couple of motors.:saweet:
  10. Fastereddie
    Aug 6, 2016
    877
    1,034
    Henderson Nevada
    Build(s):
    Yeah, them was good times.....
  11. Desert_K5
    Apr 23, 2016
    268
    233
    The 80's called and wanted their grill back. Swapped the parts suburban grill onto the K5
    UpnAdam likes this.
  12. Desert_K5
    Apr 23, 2016
    268
    233
    Had an offer made for the Suburban and it's gone. Wheels went with it @Greg Ducato. Replaced it with another K5. 203 needs gone through, then it's ready to go.
  13. Desert_K5
    Apr 23, 2016
    268
    233
    Don't want to hijack @Fastereddie 's thread with my questions. There was mention of a doubler over there and I'd like to hear from people that use them. As of yet I don't rock crawl but wouldn't mind doing the Blazer Bash (next year) and some local runs. I have a ton of desert history that ranges from pro/expert desert motorcycle racing, retrieval / checkpoints for BITD and the local AMA Racing chapter. So background is mostly high speed stuff and never had a use for more than the stock transfer case.
    What are the pros and cons of install & use of a doubler? Will it benefit me considering my blazer's intended use or is it beneficial for only rock crawling?
    I have 2 K5's that have the th350/203, and if I can swing it I'd like to swap an ORD 205 into the blazer pictured above, unless there's a better solution.
    sreidmx likes this.
  14. 454Sub
    454Sub 5/8 ton status
    Apr 11, 2012
    2,764
    1,141
    Southern Illinois
    Build(s):
    Swap a 700-241 and dont look back. OD plus deeper first plus better/lighter low and it's a bonus all the way around.
  15. sreidmx
    sreidmx Fortify Offroad Vendor
    Oct 24, 2013
    7,158
    5,801
    Morongo Valley Ca
    Build(s):
    5
    I think it adds purpose, practically gives you 3 gears for every scenario.
    Figure this, you know a desert truck will flex and crawl just fine, now add the gearing for slow going.. that's gonna be a fun truck. The low gearing makes things that were challenging before seem like a joke.
  16. JoshHefnerX
    JoshHefnerX 1/2 ton status Premium Member
    Jan 7, 2015
    2,987
    1,518
    Glendale, AZ
    Build(s):
    Doubler is tight fitting in the short blazer wheelbase.
    sreidmx and Desert_K5 like this.
  17. Fastereddie
    Aug 6, 2016
    877
    1,034
    Henderson Nevada
    Build(s):
    Magnum. Its only money. Lol
  18. Desert_K5
    Apr 23, 2016
    268
    233
    What about an Atlas?
  19. sreidmx
    Oct 24, 2013
    7,158
    5,801
    Morongo Valley Ca
    Build(s):
    5
    Dual np 205
  20. Fastereddie
    Aug 6, 2016
    877
    1,034
    Henderson Nevada
    Build(s):
    What is this you speak of ?
