90 K5 Rear suspension troubleshooting (bouncing)
Dave101
Registered Member
atlanta
I have a 1990 K5 and the rear suspension is very bouncy and looking at the truck it seems to sag just a little in the rear. I can't tell if it's the leaf springs or shocks. Any suggestions?
I believe the suspension is stock and there is no added lift.
I will post some Pics tomorrow!
Thanks for all the Replies!
I didn't think k5's came with a stock ubolt flip. Maybe it was just the trucks that didn't. That shock is looking a little weird, almost bent. New shocks certainly wouldn't hurt. You can have them checked but if the truck's bouncing that is an indication of bad shocks.
Mine bounces out back,but its because the upper shock mount on the driver side has broken in two pieces. No shockage on that side.
I believe one of your shocks is shot. Looks like you have the expensive Edelbrock IAS shocks too.
I'd replace them with something a little less expensive
As already mentioned bad shocks typically cause the bouncing issue. However I'm looking at your pics and not real sure what the shiny u-bolt clamp thing on the springs is for (second pic down). It also looks like it's rubbing on the shock......this could be at least part of the issue?
