I have sent far less rusty trucks to scrap.
That old thing is definitely getting a second chance, I can’t send it to a junk yard.
Where did you get the cab corners from?Yeppers !!!! That pretty much nails the same area I am dealing with, I did buy new cab corners, rear front floor pans, and under floor supports for the area closest to the raised area into the back.prior to it raising in to the bed area. I also need a cross support for the top of the raised area if anyone makes a replacement part!??!
done... They just simply told me "We don't have that piece but thanks for contacting us." Looking to start this exact project on mine early next week.They wont have them done in time for me, but I'll write AMD as well.
I feel so much better knowing I’m not alone, lol... just pulled off all of the makeshift floor panels from the previous owner, and was blown away at all that had rusted out.
Definitely worse than mine but not by much !! You get the RUSTY metal award LOL, Nothing that several patch panels can fix along with some fabricated patch panels that aren't available. My floor is done and the cab corners are on along with the inner and outer rocker panels beneath the doors. I also have my left box side on and it positioned well at the back and then kind of lost its way over the wheel well bolt holes, so some of the front sheetmetal holes will have to be redrilled to make it fit right and seal. I did buy new floor pans but after we got them and saw that they didn't have all the angles, bumps and curves that the factory pans had in them, we just cut repair flat panels out of them and removed the rust and welded and riveted them in place. Outer boxed floor areas had to be fabricated on the drivers side along with the lower B pillar post areas. No worry about the lower seat belt nut as 01 seats are installed in the blazer for in-seat seat belts and power seats (I'd really like to find a set of newer seats and end up with heated seats in the winter time, even though it will probably never see the salted roads of Iowa !!!).
I have been getting more notifications of new sheet metal tbey are offering. New core support just came out along a couple of grilles. Guess I'm gonna have to keep bugging them lol.done... They just simply told me "We don't have that piece but thanks for contacting us." Looking to start this exact project on mine early next week.
Who are they, I have looked through many suppliers and nobody makes the B pillar post areas and no one seems to have any box sides anymore. You would think that the boxed foot area on the rear floor would be easy to bend and spot weld up as a replacement part for the back seat floor area.I have been getting more notifications of new sheet metal tbey are offering. New core support just came out along a couple of grilles. Guess I'm gonna have to keep bugging them lol.
Who are they, I have looked through many suppliers and nobody makes the B pillar post areas and no one seems to have any box sides anymore. You would think that the boxed foot area on the rear floor would be easy to bend and spot weld up as a replacement part for the back seat floor area.[/QUOTE
Auto Metals Direct or AMD. Web address is www.autometaldirect.com From what I have researched and from a couple of friends who have used their products, they are pretty high quality.
Hey Gentlemen Jimmy, I have braced the fender on the left from the floor and used wood to brace from the floor down to the frame. I also put a brace running from the A pillar to the B pillar top and bottom. My rockers inner and outer are rusted terribly. I had already cut out the rocker and slowly kept cutting until I found this mess. I left as much floor as I could. The inner rocker is rusted so bad I don't think there will be any support from it when I cut that support on the floor to my B pillar thats when it gets shaky! Thanks for the advice and I will definitely beef it up like you said.I would suggest leaving as much of the floor in place as you can while replacing the Cab support in the pic above. You could brace under the outer rocker with a jack and a piece of wood/angle iron whatever to help hold the load when you cut it out. If the rear cab/floor support on that side is shot too (they typically are with that kind of rust) you might want to replace that first to add some more stability. I just went through that too. #Ihaterust It’s a good time to beef up the weak factory floor and bracing while your in there.
That patch job you did on yours looks great. I am ready to get to that point asap! LolI would suggest leaving as much of the floor in place as you can while replacing the Cab support in the pic above. You could brace under the outer rocker with a jack and a piece of wood/angle iron whatever to help hold the load when you cut it out. If the rear cab/floor support on that side is shot too (they typically are with that kind of rust) you might want to replace that first to add some more stability. I just went through that too. #Ihaterust It’s a good time to beef up the weak factory floor and bracing while your in there.
Those seats are nice! They look comfortable like a recliner. Thanks for the help!Thanks. It sounds like your braced up good for what you’re working with. Like Cash said, “one piece at time!” You’ll be happy you took the time to make these repairs when it’s all done.
I think the original design of the floor braces and rockers leads to problems... any water that gets into the front and rear braces drains right into the rockers that are pinch welded all the way across and no where for the water to go. I put a couple of V shaped notches on the inner rockers for some drainage.
On A side note I just got my seat upholstery finished and threw it in this weekend for some motivation to keep going. I am happy how it turned out.
Me too lol!!I have been getting more notifications of new sheet metal tbey are offering. New core support just came out along a couple of grilles. Guess I'm gonna have to keep bugging them lol.
