looks great!
Similar. Just had this wrapped this month!I would suggest leaving as much of the floor in place as you can while replacing the Cab support in the pic above. You could brace under the outer rocker with a jack and a piece of wood/angle iron whatever to help hold the load when you cut it out. If the rear cab/floor support on that side is shot too (they typically are with that kind of rust) you might want to replace that first to add some more stability. I just went through that too. #Ihaterust It’s a good time to beef up the weak factory floor and bracing while your in there.
Nice work! Hope mine looks that good when I'm done!
So, I was recently in touch with AMD once again and they said that it is planned for the end of 2021 SMH.I messaged AMD recently and they indicated that they have the panels behind the B pillar and in the corner in the works. If everyone will start sending them messages expressing need, it might speed things up a little bit.
What did the seats come out of?Thanks. It sounds like your braced up good for what you’re working with. Like Cash said, “one piece at time!” You’ll be happy you took the time to make these repairs when it’s all done.
I think the original design of the floor braces and rockers leads to problems... any water that gets into the front and rear braces drains right into the rockers that are pinch welded all the way across and no where for the water to go. I put a couple of V shaped notches on the inner rockers for some drainage.
On A side note I just got my seat upholstery finished and threw it in this weekend for some motivation to keep going. I am happy how it turned out.
Fronts are from an 02 tahoe (I didn’t want the inside armrests), center console from a ‘13 silverado, rears are from an ‘08 escalade.What did the seats come out of?
How did you mount them? Cut and weld on the underfloor mounts from the donor vehicles? That is seriously awesome work and they look phenomenal.Fronts are from an 02 tahoe (I didn’t want the inside armrests), center console from a ‘13 silverado, rears are from an ‘08 escalade.
